hey loburbon, Just wondering if this comp happened to be in alamagordo on the 28th. I was the guy with the white hyundai accent in your girlfriend or wifes class (she had the white expedition right?) I heard you talked to serge at K & B about the SX's drive down and talk to him in person im sure he will give you a deal
hi , i'm new to this site and i run my suburban yesterday for the first time at a comp and i'm confused. my box is built and tuned at 45hz but when i ran through my peak was 35hz. do ineed another box tuned to 35hz? also i'm running 4 rfp312's off a t20001bd at 2ohms, is a 142.6db's a good score in a 1983 suburban, with full interior, no dynamat, no nothing. my next question is would the re sx subs be better then the p3's i have now? my scores for yesterday were sb3 140.9, stock 601-1800 142.6, and superportwars using only 2 subs and 1 port, my box is chambered down the middle with 2 subs per side, i hit 159.1. are these decent scores? sorry for the long first post, i just had a lot of questions.
did you run a sweep or just a bunch of tones? usually your peak note will always be higher than box tunning. if you really peaked at 35hz, your box is not tuned to 45hz.
how big is your box? how big is your port area?
i would only switch over the the SXes if i were to grab another t20001bd.
btw, how much are t20001s goin for these days?
refs: chode69, superduper
yep it sure was, i talked to serge on monday about the sx's i'll drive down there when i'm ready to do the swap, thats just a long drive. and your close it's a white explorer.
i talked to gerald at probox about that, because i always thought that to but he told me when he designed that box it was designed to go all the way back against the wall firing forward, and by turning it backwards it's creating standing waves and changing everything, so i turned it around like he said and by ear it's much louder, i'll be taking it to midland on saturday to meter it and see if it changes. the box is chambered 4.5cft per side i'll have to double check on the port size though. i plan on eventually getting another t20001bd, but i want to get my subs and box redone first. they usually go for $1499, but i get a much lower cost then that.
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
2 batcap 4000's 1 batcap 2000
dual alts.
154@37hz and climbing
http://www.cardomain.com/ride/3231683
http://www.myspace.com/torque150
  • Who's Online   0 Members, 0 Anonymous, 2097 Guests (See full list)
