so as the title says i need to know if anyone has any home remedies to fix a scratched xbox360 game
R.I.P!
(Nov-29-2009)
92 explorer
current build
toothpaste(the all white stuff), or car wax. Or try saving it to your hard drive. If none of that works Rent the game at blockbuster and switch the disc's lol.
2008 Dodge Ram 2500 6.7l Cummins
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
Audio Technix Wiring & Sound Deadener
My Youtube
Feedback
yeah i googled it and the toothpaste came up but alot of people said it dont work so i donno what to do i dont really wanna try it cause i might just go blockbuster and see if they can fix it with the machine
thread over
R.I.P!
(Nov-29-2009)
92 explorer
current build
crackdown and i went to blockbuster and they fixed it and it was free cause they couldnt find the code so who cares
and it still dont work it freezes when it trys to load my saved game
R.I.P!
(Nov-29-2009)
92 explorer
current build
Did you try to Install it to your harddrive and play it from there? I have a burnout disc, that is cracked and wont go past the main menu if playing on the disc, but I installed it to the Harddrive and all it needs to do is read the disc in the tray so the name comes up, then you play from the Harddrive and it doesnt use your disc while you are playing.
You can also do what James said as long as you dont play on Xbox live, cause if they catch you thats a perma ban on your Xbox console.
Edit: The toothpaste trick has worked for me a few times.
Edited by CaptainzPlanetz
¿ǝɯɐƃ ǝɥʇ
this is gonna sound stupid but:
smooth peanut butter...smoosh some on, use your (clean, like wash before hand) finger to swirl around in circles around the disk, like 3 times (itty bitty overlapping circles, until you've been around the whole cd 3 times).press hard and dont be a wuss, put it on the counter so you dont bend and break it. Then run it under a tap and use your finger to get it all off. finish with a microfiber cloth or soft towel. Then take a (new, as in unused and undirtied) hi-liter and basically color it in, in small overlapping circles (for both of these think of waxing your car...peanut butter is like a cutting compound and the highliter is like a wax, use the same motion and everything)
then wash off and clean with a nice soft cloth. if that doesnt work, its too messed up. I've brought a lot back from the death this way. and somehow it works better than even like mother's plastic polish.
Team DC
LOL, I will have to try that, I have a NFS Carbon disc, that hasnt been working and has been in the game case behind the DVD's collecting dust for about a year now.
¿ǝɯɐƃ ǝɥʇ
yeah i try'd installing it and it says its not supported and i ended up deleting all my downloaded content and saved game and it now works so im happy for that and thanks guys for all the help
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 867 Guests (See full list)
