Dmo Posted October 21, 2009 Report Posted October 21, 2009 I previously posted this in the anything category: I'm new to building sub boxes. I have an idea for one, it contains four ported enclosures for 10" subs. The two smaller enclosures are abviously is to get the tighter bass, and the larger enclosures for the deeper bass. I would hook up the smaller enclosures together up to one amp, and another amp to the larger enclosures. I already did the math and all of the enclosures are within the box requirements, I even dew it up in a CAD program just to see what it would look like. What I was wondering was if I did build this, would it sound good and work? P.S. - It's going into a 1988 Volkswagen Golf EDIT: Here are some pictures of the design: - Dmo
bigbodylexus Posted October 21, 2009 Report Posted October 21, 2009 Actually I'm curious as to how that would sound, I guess if the power was the same I'd try it 1990 Chevy Suburban (Big Booty Judy) (4) Sundown Audio Zv5 18's (1) Sundown Audio Salt 12K (1) Sundown Audio SAX-100.4 (1) Sundown Audio SAE-50.4 (2) Crossfire ST-1 Tweeters (2) Obsidian Audio ST-1 tweeters (4) Sundown Audio Neo Pro v3 6.5's Saving 2nd Bass
CaptainzPlanetz Posted October 21, 2009 Report Posted October 21, 2009 I previously posted this in the anything category:I'm new to building sub boxes. I have an idea for one, it contains four ported enclosures for 10" subs. The two smaller enclosures are abviously is to get the tighter bass, and the larger enclosures for the deeper bass. I would hook up the smaller enclosures together up to one amp, and another amp to the larger enclosures. I already did the math and all of the enclosures are within the box requirements, I even dew it up in a CAD program just to see what it would look like. What I was wondering was if I did build this, would it sound good and work? P.S. - It's going into a 1988 Volkswagen Golf - Dmo Make all the chambers the same size or else it will most likely sound like poo, if you want midbass get a pair of 8's put them in a sealed box or high tuned box, off a seperate amp, and where your sub amp frequency cut off on your amp, that is where you will put the lowpass filter on the amp for the 8's. Edit: Just fully read the post, it sorta makes sense, as long as the amps are seperate and the filters are set differently, so they both arent trying to play the same notes at once. ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
Dmo Posted October 21, 2009 Author Report Posted October 21, 2009 alright ill just make them the same size
