My F-150 stock floor body drop/custom truck build
Truck hasn't changed much, it is still worked on when time permits.
The dash wasn't too bad to get to fit, I got it at a junk yard and had them cut the pillars, and floor then send it as one unit still attached to the firewall. The shop was then able to cut the brackets off the firewall and weld them to mine. Since that body style expedition has the same firewall as my truck it was as simple as swapping everything over. The steering column was different and it wasn't worth the effort of making the new gauges work so I kept the ones that were already in my truck. You will need to make custom door panels since the the Expy doors are shorter than the F150s.
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
  • 4 weeks later...
