update. Clamped my 3250v2
rumproast789
Here are the results
Freq---------ACvolts--------ACamps--------Ohms----------Watts
24------------62--------------21.7------------2.857------------1345
33------------68.8------------23.1------------2.978------------1589
38------------64.9------------17.7------------3.66666----------1148.7
40------------62--------------19.7------------3.147------------1221.5
45------------54.4------------17.4------------3.126------------946.7
50------------57.5------------23.2------------2.478------------1334.2
55------------53--------------27.1------------1.9557-----------1436.3
60------------52.2------------29.2------------1.78767----------1524
65------------47.2------------26.6------------1.7744-----------1255.55
70------------39.9------------24.8------------1.60887----------989.5
75------------42.5------------23.2------------1.831896---------986
80------------42.1------------21.8------------1.9312-----------917.78
Now I'm on a btl 18" fully loaded I think in an 8^3 box tuned to 33hz.
It is supposed to be dual 2 ohm, wired to one ohm. I will be pulling out the sub tommorow to check the leads. I can't remember what they said before but I have a feeling its wired to 2 ohms which makes me sad.
I'll get to the bottom of this.
Anyone know what my problem is? maybe I did it wrong, or maybe its wired to 2 ohms.
LMK, otherwise those are the ratings I got from the amp.
All on a stock headunit btw.
2002 ford explorer
200 amp rewound alt
single 18" Fi btl fully loaded
2 1750's
2 c&d tech 88amp/hr batts
2 ought wiring
cdt component set up front, cdt coaxials in back
Kenwood eXcelon KDC-X693
AC volts is pretty much on the money. Ohms... are to be expected. Even with a D2 that's well within acceptable range for impedance rise.
The way your voltage dives I'm pretty damn sure you have your low-pass filter set to something silly, approximately 60hz by the look of it.
EDIT: 1589w @ almost 3 ohms is pretty damn respectable man.
10.x volts fo' life!
What would the optimal setting be. Im setting the gains on mine tomorrow and want to get the rest of the settings as correct as possible. I have my bass boost at 0 and my LPF at around 80-100hz. My gains are at about 50% and have no distortion at full volume. Subsonic is around 20hz.
Im pulling hte sub out tommorow guys and checking impedance and changing speaker wire. And yeah your right about hte 1500 at 3 ohms. I messed with my lpf and i had it at like 80hz but i think i might have changed to about 60 hz or so. Turn it up past 80?
any reccomendations?
I have it at about 57 ac volts on the gain, and used the bass boost to make it about 58 ac volts. bass boost made a pretty decent amount of difference. I know everyone says to not use it, but it really seems to make it a LOT louder...?
subsonic i think is around 24 hz or so?
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
Was the car on or off during testing?? Also what was the voltage dropping to during the tests??
U shouldn't be worried my friend about a D2 woofer being wired to 2ohms, since it's impossible. You're seeing the higher ohm loads because that is impedance rise.
To Kent B - Please explain how the OP could wire to .5ohm with a D2 woofer?? lol
Pioneer AVIC-N2
He meant if it turned out to be a d1 ohm I think.
And I know that it could be impedance rise, but I'm going to pull the sub out and see if i got dual1 ohms on accident. I know I ordered dual 2 ohm but maybe fi messed it up somehow.
Or maybe one coil is hooked up or something.
So change my subsonic to my tuning level. got it.
Yes It is a remote gain, I have that turned all hte way up when setting the gain and other settings.
Car was on during testing, I think dropping to about no less than 12v's
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
Have you checked the ohm load of each coil? You don't necessarily need to take the sub out for that. Though it would be wise to visually check the sub.
As far as tuning, just leave the remote gain unpluged.
Also try checking your RCA voltage. If pre-amp voltage isn't the cause, then its either amp or sub. Also make sure you have a clean consistent input to your headunit (no Aux iPod plugs). Make sure your eq is flat and your playing a 0db test tone.
Those amps are rated at >3400RMS at 1-ohm. That impedance is a bitch, if in fact that is your problem. Still, that amp is rated at >1900WRMS @ 14.4V so I don't suspect the amp to be the problem.
Anyways, let us know what you find out. I just got my x2 3250v2's and have yet to hook them up.
tested again put new speaker wire in straight run through the port. turned lpf all the way up, subsonic all the way down.
Freq---------ACvolts--------ACamps------------Ohms------------Watts
24------------69.4------------27--------------2.57------------1874.07
50------------58.3------------25--------------2.332-----------1457.5
60------------54.2------------29.3------------1.8498----------1588
80------------45.1------------23.7------------1.9029----------1068.9
Only CD I had had these freq's on it.
I didn't measure voltage again.
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
  • Who's Online   0 Members, 0 Anonymous, 763 Guests (See full list)
