1. Product:
FS: Nightshade Pole Plugs (Aluminum)
2. Specs:
Stalk = 75mm long / ~33mm wide
Cap = ~71mm across / 15mm high
3. Description/Condition:
New pole plugs - made in the USA down the road from us in Troutman from solid aluminum.
Designed to direct air flow from the woofer cone motion behind the former for enhanced cooling vs. a pole vent.
These are also a big chunk of aluminum so they also act as a heat-sink.
Please check fitment yourself... will fit quite a few motors but not all motors. Will *not* fit first production run of NS motors, but will fit all later runs. I have used them in TC-9 motors and a few others as well myself.
4. Price:
$15 each + Shipping
6. Pictures:
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
Jacob, would these fit my 15" Nightshades? These have the one off copper voice coils. if they do fit, would it change anything with the T/S specs that I would need to worry about?
97 Maxima SE
Bunch of shit going in, check out the build
There is almost no change in T/S... I measured a small decrease in inductance but no other changes.
It is NOT going to be easy to add this without re-coning the driver... at the least you would have to cut off the dust cap to add it and then try not to get glue between the gap and coil former. I suggest re-coning if you want to add one.
As for fitting your motor... I don't recall what run of motors that one is from - you can measure the pole ID and tell if it will slide in.
- Jacob Fuller
This topic is now closed to further replies.
