i drive an '01 chevey balzer 4.3l 6 cyl. ok so i was driving to work the other day and my check engine light came on so i broke out the trusty snapon code reader and it said i had a random multiple misfire... ok so i changed the spark plugs, still did it, got new wires, didnt help and finally did the cap and still nada. im stumped i cant figure out why it still has a misfire. i cleared all the codes drove around for a little bit and it came back. so i read it again and it still came up with the same problem. any ideas?
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
my 97 silverado has been doing the same thing sense i swaped out the 105amp small case for the 140amp large case from a tahoe. my ecu burned up the same week and i got a new one from a junk yard, so i dont know if its the ecu or the alt, but if you figure it out, let me know.
CAUTION!
POOR INSTALLATION MAY SHORT BOTH YOUR SYSTEM AND WALLET
Being you have an actual scanner, did you go into the misfire counters and see which actual cylinder is missing to start with? you may have a leaking pressure regulator on the injection spider set up thats causing the miss
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
i havent, thats a good idea though ill see if i can do that. i was doing some research and someone mentioned the cat converter begin a prpblem from the car running rich which i forgot to mention. it also came up running rich
New Project
[top secret]
anyone else?
New Project
[top secret]
well, the 96-00 vortecs are famous for multiple problems, such as egr valve, spider injector and assembly, fuel pressure regulator, etc..... however, it could be something minor, like a bad knock sensor playing with the timing or could be low fuel pressure from the pump....many things could cause this....
  • 4 weeks later...
could be a bad module in the distributer or a leaking intake manifold gasket the vortec's are known for that aswell just did mine on my suburban. are you losing any coolant?
Edited by yoda132
99 suburban
20" boss motorsport wheels
big 3 installed (thanks Iraggi)
alpine 9886 deck
kenwood 11 band eq
fosgate t5002 amp running sub
kenwood ps200 amp running components
jl xr components in front doors
jl xr 6.5 in rear doors
jl in rear roof
1 FI Q 18" with bp
enclosure 8 cubes 138 sq" port 34hz
Iraggi 220 ho alt
(RF 1500bd coming soon)
not a big help but our schools wood shop teachers silverado had multiple misfirings (every stroke) and a fuel injector cleaner worked wonders. the truck didnt sound like a diesel anymore.
write down the code and look it up online.. if not, send me a PM with the codes and i can look it up when im at school.
Hustle hard, Stack paper,
It's alright, ya'll haters,
It's nothing, We major,
You see me, Hi Hater! =)
~ Manio
what other engines would fit a 1993 geo prizm 1.6 liter? im trying make it a sleeper since everyone considers it a piece. i would really appriciate some help here. i wanna know what kinda engine would fit the stock motor mounts with out doing any adjusments. or if i do have to do ajustments which engines would fit? thanks
  • Who's Online   0 Members, 0 Anonymous, 693 Guests (See full list)
