4 gauge wire!?!?! you need to get your self some zero... and that new battery
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
I got the new battery, and every1 has said 4 guage is fine, do you really think it will make that big of a difference?
SUCCESS is a decision, NOT a dream. You have to name the price you are willing to pay to get it.
"You didn't have an ice pick on you? Amateur. " -- Wax from Fchat.
yeah i'd switch it out.. since that amp accepts 0 gauge right ? couldn't hurt
Guest DC Power Kyle
0 gauge will make a difference in voltage drop from the front of the car to the back... less resistance :D
It takes 4 guage. But I am sure 0 would fit. Guess I will tighten up that ground and see if that fixes it. If not, looks like new wire.
You've got a loose connection. If the area where the wire connects to the amp is hot too, then it's at the amp. But from what you've said, it sounds like a loose connection at the battery.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
is the wire hot or the terminal?
normaly if the wire jacket gets hot its pullin to much current n cant keep up wit the demand with that amp
4guage will work but 0guag-1/0 is what u need with true 1k rms n up, i wouldn't of even tryed it without 0guage cause with that high of resistance n causein the wires to get that hot wonder what its doin to the amp?
ied fix that ground but get a decent 0guage kit n use it
if u want for the cheap n get decent wire get this kit, i got the 4guage when i had my honda n it worked great wit a 500rms amp
http://www.darvex.com/SQK0/Sound+Quest+0+Gauge+Amp+Kit.html
and put meade in for cupon code for i think a 20% discount too
anyways sound quest is made my stinger so its a replicable company
hope this helps
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
oh ya, check your door step plates n see if a screw might have went into the wire unless u ran it somewere else, i was in a hurry one day n threw in a 8guage kit to play wit in my bro n laws blazer n a screw from the step plate went into the wire n caused it to short out n blow every fuse we put in n make it get hot
but ya check all your connections at ever point n make sure theres no loose strands comein out of the wire touchin somewere else on the amp or other input post, n check that the wire is tight at battery n that the post is decently tight but do not over tighten the battery post cause it will break off n u'll be up shit creek
can u take pics of how this is setup so we kinda get an idea on what ur workin wit here?
Make sure your positive does not touch the negitive because that happened to me once and i nearly got fried lol with my old battery so i went and bought a brand new energizer battery that goes from 700 cold crank to 850 regular.
hope this helps
VehicleCurrentlyOwned:2000Malibu
\/MySystem\/
Ken-Wood HeadUnit
Cars interior panels Custom blue Done by ME
Pheonix Power block running both amps
Stinger pro series four gauge wire flex material
RimsBrand:Polo
Interior lighting Blue neon bars under and around dash
Capaciter:Pyle Dryver 1.7 farad digital meter read off new(INSTALLED)
http://blog.sounddomain.com/photos/orion/april_21_07_004_2.jpg
http://www.dcsoundlab.com/images/header.jpg
  • Who's Online   0 Members, 0 Anonymous, 2884 Guests (See full list)
