IH8PunkRok Posted October 25, 2009 Report Posted October 25, 2009 im trying to find one. my friends girlfriend wants some bass and i need to know ifthere are things i need to work around. im not sure if there is some amp hidden in there somewhere or if i need to use rca or high level inputs. thats the only issue i have right now if anyone can help id be very thankful -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
Guest Posted October 25, 2009 Report Posted October 25, 2009 http://www.directwholesale.net/diagrams/diagrams.asp?link=DW found your car on there but sadly doesnt give direct links.
IH8PunkRok Posted October 25, 2009 Author Report Posted October 25, 2009 thanks man if you click on 1998-2000 it brings up the diagram that should help me a lot -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
jbondox Posted October 25, 2009 Report Posted October 25, 2009 regardless if the vehicle has the Bose system or not, behind the radio you will have the high level outs in full range. you want the white and the pink twisted pair. the brown striped is ground The blue and white wire located behind the amp in pin A5 is the remote turn on for the Bose amp and the antennas, you can use that for your amp turn on. you will need the removal tools that slide in at the bottom corners, you will see the slots for it. SMD SuperSeller VerifiedJbondoXJames Shields
murderedc230 Posted October 25, 2009 Report Posted October 25, 2009 Yeah there is a bose amp in the car somewhere. In mine, I just put a kenwood deck in and Ran RCA's to the trunk to an aftermarket amp and ran that amp to my speakers. Made life alot better. As far as a wiring loom goes, VW and Mercedes should be the same. Thats what was used in mine.
c_stud Posted October 25, 2009 Report Posted October 25, 2009 Yeah there is a bose amp in the car somewhere. In mine, I just put a kenwood deck in and Ran RCA's to the trunk to an aftermarket amp and ran that amp to my speakers. Made life alot better. As far as a wiring loom goes, VW and Mercedes should be the same. Thats what was used in mine. the amp should be in the trunk on the passenger side and should look somewhat like this one 1998 Nissan 200sx NOW: Dex-p98r head Planet Audio 300.4 mids and highs Planet Audio/Pioneer tweeters/crossovers Skar SK1500.1 3 SKAR Vvx15 dual 4 wired at .63
murderedc230 Posted October 25, 2009 Report Posted October 25, 2009 yeah thats right. It was about 3 years ago when I yanked it out. Couldnt remember
jbondox Posted October 25, 2009 Report Posted October 25, 2009 not all had the amp, it was an option with code 801, Bose hi line upgrade. If your door speaker have the Bose logo on it then the amp is mounted vertically on the right rear wall - seat back (well just off the wall) you can also grab the wires there going into the amp as they are a hi-level from the radio including the turn on SMD SuperSeller VerifiedJbondoXJames Shields
IH8PunkRok Posted November 2, 2009 Author Report Posted November 2, 2009 another quick question. where should i be looking for a remote turn on? or what am i looking for? -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
