exactly like the picture says, just follow the diagram and you'll be good. run a wire from the negative on one coil to the positive on the other coil. then you can wire the "free" terminals to the amp, if that makes sense
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
New Project
[top secret]
sorry double post i fail..
New Project
[top secret]
For some reason I like the way you described that better than the way I did. It just seems simpler for some reason even know they are the same thing.
ooh so I just take some speaker wire and hook the positive wire to the positive coil and the negative to the negative.
what about the other ends of the positive and negative? let them hang there? because if you are only using one side of the positive, and one side of the negative.
hey whatever makes sense to you. but thankyou i try lol
New Project
[top secret]
huh!?!? no the free ends go to your amp. other wise your gunna have a sub and a box with some random wires in your hand scrathin your ass goin.. wheres the sound!?
ok lets start tfrom the begining. take 1 piece of wire. hook it into the positive terminal on one coil and attach the other end to the negitive terminal on the other coil.
then run wire from the open positive terminal to the positive on the amp
then run negitve from open neg. on coil to neg. on amp
and viola sound.. assuming the amp is hooked up correctly
New Project
[top secret]
Posted (edited)
what I am asking is do you use negative wire or positive wire to connect open negative and positive terminals on the subwoofer.
Edited by Cozmoo
coppers copper, the only difference is color
New Project
[top secret]
