First started with 10 diamonds in a wall it didnt come out like i wanted i rushed it and messed the box up so i decided to sell off 5 and keep 5 heres where i stand of for now
99 ext cab f150
ap3000d
5 diamond d1 12s wired at .8 ohm
braced internally with 2x4s box is 49 x 30 x 12
4 4" pvc ports 14.5 long
box tuned at 34 hz
Thanks
sides im waiting for an staple gun so i can tie the rest of the covering down.
You're wiring that amp to .8ohms?? If so u might as well just light it on fire ahead of time, since each board will be seeing .4ohms each and bridged to .8ohm total.
Pioneer AVIC-N2
maybe.. maybe not.. had my RF T4ke wired at .5ohm it never lit...
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
hes talking about the ap3000 im guessing its A/B class
03 Ram 1500 3.7 v6 quad cab
H/U: Pioneer 4200UB
Subs: 4 DC LVL 4 15s D1
Sub Amp: 2 Crescendo 3kwp strapped
Highs Amp: Crossfire xp240.2
Highs: Crossfire 2 rs69, 2 rs52
Alt: DC POWER ALT 270XP
Batts: 5 sprinter data safe
Big 3 0ga
New Truck 03 Ram Build Log 6 DC Audio lvl2 15's
My Wrecked 99 Dodge Ram Sport Build Log
02 Ranger X Cab Build
02 Ranger Build 2
http://www.dcsoundlab.com/
My linkhttp://www.crescendoaudio.com
http://www.dcpowerinc.com/
http://www.crossfirecaraudio.com/
Youtube Vids
That is a totally different amp, idk why u even mentioned that. I've run tons of amps @ .5ohm or lower before but it's irrelevant if it's not the same one he had. If he is talking about the Audiopipe 3000D then I have 100% confidence that it will be blown in a very short period of time.
Doesn't seem like the OP understands that the 3000D is a 2 channel amp, that has 2 1500D boards each one wired to 1ohm and bridged to a final 2ohm load to reach its highest power output(this is what AP rates it at). It's a serious risk to even run that amp at 1ohm bridged because the 2 internal boards aren't happy each seeing .5ohm at all. They will get very hot very quickly and will be pulling a ton more amperage than @ 2ohms without seeing a big power gain.
Pioneer AVIC-N2
99 ext cab f150
ap3000d
box tuned at 34 hz
Are u really using a staple gun to keep the carpeting in place?? I'm still confused why u kept 5 instead of say 4 or 6. It just makes thing a bigger pain in the ass wiring wise and it just looks odd to me with 5.
Pioneer AVIC-N2
