XS Power
WHICH BATTERY FITS UNDER MY HOOD ITS ONLY GOING TO BE SUPPORTING 1000WATTS
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
1 optima yellow top (rear)
1 xs power 5100r (front)
big 3 and 1 run 1/0 stinger wire
my build
my rebuild
2006 going to b running a us amps md1d
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
  • 3 weeks later...
Actually your vehicle calls for a BCI group 27F battery.
Depends on how much play you have in your stock battery cables as to which batter would be best. The 2700 would fit the dimensions of your stock battery and give you a huge jump in power, but your OEM battery has the post reversed. If you have enough play in your cables you could mount the 2700 backwards and run your cables that way. If you do not have a lot of play in the cables then you could go with the 5100R which would have the posts the way you need them and be smaller than your OEM yet still providing you with a big jump in power.
If you used the 5100R as your starting battery it could still power a 2000 watt system easily. If you have any questions just let me know.
i got that battery up front in my toyota camry its solid
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
