a_steezy Posted November 1, 2009 Report Posted November 1, 2009 always wanted to go with pvc type round port i have no idea how to tune it, if someone has a link or just wanted to do it to help me out that would be sick box is 40x16x14 for a DC lvl4 15" and i want it tuned around 36-38 also can you buy the flairs at the local store like homedepot? is it alright to run just straight pvc without the flairs? thanks '98 Dodge Durango 5.9L 5% front windows, 2.5% on all backs Alpine CDA-9883 Kicker ZX350.4 Kicker KS650's in all doors Kicker 1/0 hyperflex
a_steezy Posted November 1, 2009 Author Report Posted November 1, 2009 do you know if a local store, lowes or home depot would have a flare? do i need a flare? '98 Dodge Durango 5.9L 5% front windows, 2.5% on all backs Alpine CDA-9883 Kicker ZX350.4 Kicker KS650's in all doors Kicker 1/0 hyperflex
Mr Bigolsworth Posted November 1, 2009 Report Posted November 1, 2009 do i need a flare? yes u will want a flare, other wise ur box will wissle. u may be able to find them at locol store but dont hold ur breath. but u can make one ur self, with pvc and a heat gun, just heat the pvc and press down on the ground and rotate. it will flare out 2002 chevy avalanche Currently have: 2 dc xl 18 set of T2652-s scv-6k Ct sounds 75.4 270a mechman xp3000 d3400 Wanted: saz 200.4 Second set of T2652-s D3100's deadner
Guest Posted November 1, 2009 Report Posted November 1, 2009 a flared port is not needed. sure it helps with the air flow, thus needing less port area for a box. but you can get away with PVC ports perfectly fine. in a basic range of efficiency i think it goes, flared circle, normal circle, slot port.
a_steezy Posted November 1, 2009 Author Report Posted November 1, 2009 cool cool, i'll probably play around with making the flairs if not it's all good. how does this sound http://psp-inc.com/tools.html Volume of box in cubic feet 4 Tuning frequency 36 Port diameter 4 Number of ports 4 then it says i need 23.xx" of port. so cut the 4 pieces into a little under 6" will four 4" ports be good on the port area '98 Dodge Durango 5.9L 5% front windows, 2.5% on all backs Alpine CDA-9883 Kicker ZX350.4 Kicker KS650's in all doors Kicker 1/0 hyperflex
Nightshade Posted November 1, 2009 Report Posted November 1, 2009 a flared port is not needed. sure it helps with the air flow, thus needing less port area for a box. but you can get away with PVC ports perfectly fine. in a basic range of efficiency i think it goes, flared circle, normal circle, slot port. No, no, no, no, no the flare is what makes a round port so damn loud. Without the flare you are better off running a slot port. No flare, no way! 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
Guest Posted November 1, 2009 Report Posted November 1, 2009 cool cool, i'll probably play around with making the flairs if not it's all good.how does this sound http://psp-inc.com/tools.html Volume of box in cubic feet 4 Tuning frequency 36 Port diameter 4 Number of ports 4 then it says i need 23.xx" of port. so cut the 4 pieces into a little under 6" will four 4" ports be good on the port area that 23" means each port has to be 23" long.
03navi Posted November 1, 2009 Report Posted November 1, 2009 always wanted to go with pvc type round porti have no idea how to tune it, if someone has a link or just wanted to do it to help me out that would be sick box is 40x16x14 for a DC lvl4 15" and i want it tuned around 36-38 also can you buy the flairs at the local store like homedepot? is it alright to run just straight pvc without the flairs? thanks i am using PVC ports! 6 inch wide by 10 inches deep! Vehicle: 2003 Lincoln Navigator Exterior:Custome Air bags, Chrome Grill, 8000K Hid Low & Fogs, 24in rims,Corsa dB Performance Exhaust Amplifiers:Kicker Kx2500.1, MA Audio M700XE Batteries: 1 Kinetic Hc2400 Battery Electrical: STOCK Charging System! Tsunami 40farad Capacitor, Enclosure: 8 ft³ tuned to 45Hz Interchangeable Ports(34Hz) Headunit: STOCK! (DVD,CD,Navigation), AudioControl LC6i, AudioControl Epicenter Mids/Highs: (4)Sets Of Focal Access Component 690 CA1, 2) Sets Of Infinity Reference Tweeter Subwoofers: 2) 15 Power Acoustik Mofo Wire: Multiple Runs Of 1/0 Gauge Streetwire Cable Video: http://www.youtube.com/2treo15
