your current port area is 45
proper port area for a 5.7 cube box is 68<x<98
somewhere in that range
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Posted (edited)
im guessing u need to be closer to 6cuft but ive never seen specs for a 18" lvl3
that's the problem
Rusty told me to put it in 5-6 C.F. box
P.S. that my first time making a design
Edited by nfsplayer
well if rusty says 5-6 cubes i say use 5-6 cubes he knows best. they are his woofers. but yea 4.5 is to small can you go any bigger?
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
Posted (edited)
the box volume is 5.7, minus .6 c.f. port size, which give me 5.1 C.F.
Edited by nfsplayer
Posted (edited)
its .87cuft for port... u arent accounting for the wood... nor the end correction factor of using a slot port
5.75 after wood displ
-.22 for sub (guessed on displ)
-.87 for port
______________
4.66cuft@~37hz
and u still arent accounting for bracing displacement... which is why i said 4.5@37hz+
Edited by Decaf
