i built a box using the re box calculator tuned to 37.6hz.
i just re-checked my work here
http://www.mediafire.com/?2ypo0iymlum
and it's saying in the end it's 44.7hz
both have the same dimensions and they both say the same 'box volume' but tuning is off...
opinions?
how do you take screen shots so i can post up unless you guys wanna punch it in yourself and play with it
40" wide 14" tall 16" deep
port is 3.5"x12.5" and 11" long
Edited by a_steezy
'98 Dodge Durango 5.9L
5% front windows, 2.5% on all backs
Alpine CDA-9883
Kicker ZX350.4
Kicker KS650's in all doors
Kicker 1/0 hyperflex
sub displacement and end correction factor are usually what changes tuning
and if u use a square vs slot port since the amount of extra wood displ is different with each
give me a sec ill see what i get
what sub(s)
the RE calc is known to not be very accurate. putting those dimensions in my calculator, i came up with around 43 hz myself.
and to take screen shots, press the PrtScn (print screen) button on the top right of your keyboard. then open paint, paste it there, resize or crop if you need/want, then save it and upload it to photobucket or wherever you put your pics
EDIT: ^what he said, tho i think 7 hz is a BIG difference between the two. i did see someone tho put their total length in the port in the 'length 2' box which told the RE calc that the port was that long, plus the length of whatever the box was. so it made it super long.
Edited by ExpoSport
its the 15" lvl 4
i have sub displacement at .15" but i also set it to 0 and didn't change to much, i'll take screen shots
but fawk, 44hz is a little high for my likings and it's a badass box... hah
and for the re calculator, just put 0 for second port length or whatever, the 11 inches is in the first part
Edited by a_steezy
Alpine CDA-9883
Kicker ZX350.4
i got
[email protected] with no bracing accounted for
with bracing it should bring u up to [email protected] depending what u do
damn...
i did a double baffle and a little triangle, type brace in the center
Alpine CDA-9883
Kicker ZX350.4
just figured it out, had to reset p-bucket password and such
Alpine CDA-9883
Kicker ZX350.4
just keep using andym85's calc or expos
personally i like andy's because u see the math and equations he uses... and u can do aeroports/circular ports
did u put the correction andym85(amatt85) said to enter into cell H iirc?
can u tell me what u have for cell H17 please... it should be
=IF(A21<=L17+(J7-B18),A21-L17,J7-L17)
Edited by Decaf
ok there are two big differences
pay attention to the lengths of the port pieces... this is where its off
in andym's... the actual wood length is 9.25"... his accounts for sub displ
in the re it is 11"... does not account for sub displ (do u see how it says total port length of 17.75... this is why its lower)
so shrink the box on ROE .15cuft by shrinkin one of the dimensions (ur gonna have to use tenths) and enter in 8.5" and you should have very similar tuning
(takes a bow)
Edited by Decaf
