Well I got my mids and highs amp and am gonna be installing it today, the think is I really dont want to run an extra remote wire, so my Q is would it be okay to put a jumper wire from my sub amp to my mids and highs amp, so another wire wont have to be ran?
¿ǝɯɐƃ ǝɥʇ
That should be fine. It's when you get a bunch of amps you would wanna use a relay.
Alpine CDA-9847 HU
F Highs 2x Infinity Kappa 60.9CS Powered by Eclipse EA4200 Glass door panels
R Highs Infinity Ref. 9622i powered by HU
3x RF Punch HX2 RFD2210 Powered by MTX Thunder 81000D
Box Vol. 3.259 before displacement, Tuned 36.6, Port area 54"
thats what i did with my old setup but im sure somebody will say get a relay
My 02 Accord Wall Build
2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500
Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s
Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters
DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
your remote turn on lead from the head unit is very weak. once you split it several times you run the risk of burning it out and causing issues. for two amps it shouldn't be that big a deal.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
amps cant draw extra current through the rem
and decks dont output extra, worse case scenario is the amps wont turn on.
i have 4 amps and a stinger voltmeter paralelled in my car and it all works fine. If you're running some obscene amount use a relay. in general a deck has about 500ma of output, and an amp usually takes 100-150ma to trip the turn on.
Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build
monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now)
Team DC
Has anyone had any problems using the RCA voltage sense turn-on? That is another option I have for the amp, I believe my HU has 5 volt preouts.
¿ǝɯɐƃ ǝɥʇ
A couple buddies have done it that way and worked but I personally have had no experience in that area...
its called daisy chaining and it's perfectly fine for two amps. Three may be pushing and remember length plays a factor
2003 CHEVY TRAILBLAZER
AKA The Batmobile
Pioneer 6000UB
Sundown SAZ-3000D
2 Audio Q HDC3's
40' of 1/0 Gauge
2 Big Rear Batteries
A 38 HZ Box
KICK ASS!
I knew that term applied to RCA's but didnt know it did for Turn On Leads.
The sub amps will be on top of each other in an amp rack so that run will only be about 2 or 3 inches, and the mids and high amp will have a run from those amps that is about 6 inches.
¿ǝɯɐƃ ǝɥʇ
  • Who's Online   0 Members, 1 Anonymous (See full list)
