Designing a wall for two 18's for my car, here's what I have so far.
Feedback? Four 4 inch aero ports be ok for 10-11 cubes after displacement?
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
Any one? Starting this build tomorrow...
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
should work i would drop aero ports from the top though so you can make them the actual lenth hence my build ill upload pics in second
Edited by MXmike800
for walls a nice big ol slot port is preferred but aeros work
R.I.P!
(Nov-29-2009)
92 explorer
current build
I was thinking about a slot port, but was leaning towards aero's since I've read they're more efficient and possibly increase spl. If I go with a slot I have to get another sheet of mdf just for the port, which kinda sucks
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
Another question, when I calculate port displacement do I just count the displacement of the wood or do I also include the space in the port? Idk if anyone understands what I'm asking, kinda hard to word.
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
unless your port is the size of the whole dam box i dont think you should be worried about port displacement man youll be fine
Oh, I was just going to make this dead on if possible. OCD box = :hairtrick:
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
For wall builds a large slot port is usually the most successful way to build.. Also for 2 18s 4 4" aeros is not much port area at all. If you choose to stick with aeros I'd suggest like 3 6" aeros or 2 8", hell for my 2 15s I run a single 10" one but that's in a regular enclosure.
For wall builds aeros usually don't work as well as you would expect.
Pioneer AVIC-N2
  • Who's Online   0 Members, 0 Anonymous, 852 Guests (See full list)
