Anyone who owns a Cherokee of any year knows that the rear drum brakes are garbage. I definitely know that about mine, which is actually kind of a special model (Limited, 2001 (last year built), skid plates, tow hooks, transmission oil cooler, heavier-duty suspension -- all factory)
I've begun to notice that the rear drums are barely doing any work, so instead of adjusting them and just putting up with it, I decided to swap to rear discs. I'll be using the caliper brackets/backing plates from a '96 Grand Cherokee (have parts in-hand) and the parking brake cables from the older (rounded) Liberty...not the new boxy one. (have those on order at the dealer - should have them in tomorrow) Aside from that, the axle seals, rotors, calipers, lines and pads will all be brand new.
Pics to follow sometime soon...let me know what you think
2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix |
On 6/6/2012 at 6:32 PM, 'LZTYBRN' said:
3. Don't put speakers outside the car unless you are the ice cream man.
My feedback thread
I did the same thing to my 05 Taurus. Ford stopped making rear calipers for Taurus sedans in 1999. So pieced together a "kit" Calipers , brake cables and ebrake from an 87. Rear knuckles from a 97. I reused the spindles and abs sensors from my drums. Custom drilled rotors and caliper mounting bracket from SHOBros. It all worked out great.. only problem I have was gettin the air out of the lines fully. The dang ABS modulator sucked in a crap load of air some how... I got it out eventually.. Just watch out t can be a pain lol.
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
