Subsonic and level setting ?
DEEz NUTz
I know every setup is different... what is a good general setting of the two until i can get to a Oscope and be dead on ?
153.3 @ Turkey Drag 2009
Spl Modified 1001-2000 - Derrick Jones my alias... Wudn't accept DEEz NUTz !!!
Subsonic should be between 5-10hz below your tuning freq. gain depends on you hu output voltage or eq/line drivers.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
my prefab boxes tunes to 45 so 35 hz. and my hu is 2 volts going into eq w/ 7 v output.....
if eq is 7 volts, do your best to guess where that is on the dial, most are labeled....
if you have one of those amps that only accepts say a 4v max, and the gain goes from 4v to 500mv for example, its basically gonna be stuck on zero
and prefab ftl...set subsonic to like 30-32 unless you're running way under rms to the sub, something tuned that high means a whole lot of under-tuning notes are in songs and you need to protect that woofer.
Team DC
http://www.audiodiscounters.com/shopping/P...00D-p-3673.html here is the amp....
  • Who's Online   0 Members, 0 Anonymous, 671 Guests (See full list)
