Problems with Arc 1500dr
the4stringking
I recently was given one of these from a friend. I hooked it up to my new fi q 12 at 2 ohms and it makes a weird buzzing sound that is really quiet thru the sub, regardless of volume, until you turn it up all the way, then it gets pretty loud but cuts out and doesn't pick up non generated bass such as a bass drum that loud at all. It also sounds like it has short bursts of power and then it gets weaker.
The fuses are not external, so I haven't checked them, but I would think that it wouldn't work at all if they were blown. The ground is good.. RCA's are good and I even reversed them just to check and it still has the problem. Sub is in phase.
Any idea of what the problem is?
Old setup
2002 Camry LE
Fi Q 12" BP power in a 2.3 cu box tuned to 28 hz
Alpine MRP-1000
JVC Deck
RE 800.2 speaker amp
RE Coax 6x9's in front doors and Deck
Alpine Type S 6.5's in trunk
now...
2006 Subaru Legacy 2.5i Special Edition
JVC KDX double din
1 Run of Knu Konceptz 1/0
Big 3
Waiting to get Amp and sub(s) and speakers
maybe a bad amp
Yes I would assume so...I was just wondering maybe what the problem could be within the amp itself.
Old setup
2002 Camry LE
Alpine MRP-1000
JVC Deck
now...
JVC KDX double din
Big 3
  • 3 months later...
bump...the fuses have been checked and they work fine
Old setup
2002 Camry LE
Alpine MRP-1000
JVC Deck
now...
JVC KDX double din
Big 3
  • Who's Online   0 Members, 0 Anonymous, 1000 Guests (See full list)
