I get two different error messages when I log on to my user name. It doesn't do this when I log on the comp under my moms name. The two that show up are both runDLL ( IDK what that means ) One started about a day before the other and they wont go away. I've searched there name on the comp and get nothing. One is a yorerufo.dll the other is luwapeta.dll. What are these how do I fix this?
go to run, type in msconfig, look under the startup tab, and see if you see those under it..... if so, UNCHECK the box next to it. actually, to make life easier look at the bottom of that screen and you will see an option to check in that reads, select all, or disable all startup options, then reboot....
I love my staffie :good:
So anti FACEBOOK it isn't even funny
in the start menu at the bottom it says "Search for programs and files" type run in there and it will pop up.
Edited by G_Fresh
well it doesn't say that but there a start search button at the very bottom. I can't believe I didn't see it, it kind of blends in. But I got to them and unpicked them and she starts up without a problem. Does anyone know what these where or why they started doing this. Thanks for the help guys.
