will i need with 5.6k rms plus a air bag kit? i will be getin a 250 alt
i dont want 2 spend a grip on batterys tho that the down side
Edited by 01zx3
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
What sort of air bag setup and what amp(s) are you gonna be running?? I understand that you don't wanna spend a ton of $$ but for stuff like this you really don't wanna skimp out. Really putting your vehicle and products at risk with low voltage if you do.
Pioneer AVIC-N2
a kinetik 1800 up front and 4 2400's in the back would be a good place to start.
You need to be much more specific with the equipment you will be running if you want a better answer.
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
the amps are planet audio
1200 rms there are 4
one 400 4 ch
one 400 2 ch
and the air kit is http://www.suicidedoors.com/strut-bag-kits...focus-combo-kit
i will be changein the tank with a pancake tank
you won't be pullin that much current with a single viair 380c and those amps. You car will fit a HC1400 up front and I would put 2 HC2400's in the back. With a good HO alt you will be more than fine.
a nice batt up front and a 2 in the rear and you should be fine i'd get powermaster or something
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
Well I did the how many batterys and it came out to be three 1800 but that was just for the system...so a d12 or d24 or a 1400 in the hood and 2 d31 or khc 2400 should be good on lil volt lost?
i think two d3100s in the rear and whatever you can fit up under the hood would be fine
Edited by treossi
oh yeah i forgot to ask.. how many runs are you going to be doing from the front to the rear?
With those amps and bad setupI'd run something like a Kinetik 1400 or similar under hood, 3-4 big batts in back and an HO alt. Lots of good batt companies out there, so just compare sizes and pricing from each one(Kinetik, XS, Northstar, Deka, etc). If you could find sum of the big C&D batts that are always floating around for cheap, then I'd suggest going that route to save sum $$.
Pioneer AVIC-N2
  • Who's Online   0 Members, 0 Anonymous, 2848 Guests (See full list)
