going in to protect mode
c_stud
i had a system with a 8 gauge wiring, so i found some 4 gauge wiring switched the wiring out and now the amplifier goes in protect. so i unhooked the power and ground cables, pulled all fuses, just leaving the remote wire, and rca's attached it still went in to protect. i unhooked the remote wire and it went out of protect so i nicked the pinch-screw with the rem wire and it went in to protect again. what to do?
1998 Nissan 200sx
NOW:
Dex-p98r head
Planet Audio 300.4 mids and highs
Planet Audio/Pioneer tweeters/crossovers
Skar SK1500.1
3 SKAR Vvx15 dual 4 wired at .63
check your wiring. i dont know how you unhooked power and ground and it still went into protect. it shouldnt light up at all if theres no ground.
just do pos, remote, and ground. unhook everything else and see if it goes into protect. what does your wiring look like? are there any cuts in the line somewhere?
and make sure your ground is nice and clean, and in a good spot.
Eclipse cd7000
there's one cut in the power wire cause i was a foot short so i crimped a foot and a half on it to have a little extra
1998 Nissan 200sx
NOW:
Dex-p98r head
Skar SK1500.1
you cant crimp 4 gauge together lol. You probable have mad voltage loss there.
Eclipse cd7000
well i didn't mean to say crimp but w/e i used 2 of these and put a bolt in the middle with a wing nut on the other end and slid it in to some spiral wire tube so it wouldn't short
1998 Nissan 200sx
NOW:
Dex-p98r head
Skar SK1500.1
make a new ground closer to where your power wire ends (before you connected the two together). then see if it goes into protect still.
check your fuse up front.
Eclipse cd7000
ok i'll do it in the mornin darker than heck right now
1998 Nissan 200sx
NOW:
Dex-p98r head
Skar SK1500.1
i went ahead and did a new ground (finding grounds in a 94' cavalier there is none!) and put some better fuses in the amp and wha lah
1998 Nissan 200sx
NOW:
Dex-p98r head
Skar SK1500.1
  • Who's Online   1 Member, 0 Anonymous, 757 Guests (See full list)
