I read through those threads above and about wet myself laughing at lack of knowledge on them boards. Here was the solution they found.
Problem: ESP and BAS lights on
Fix: Replaced the Steering wheel angle sensor. Replaced SAS
Problem: Transmission shudders/vibrates
Fix: ***UNDER TSB 385 WP40***
Replaced filter and o-rings
Replaced o-ring adaptor plug
Replaced filter - transmission oil
Replaced oil - automatic transmission
Replaced hose - 1ft. fuel and vapor
T-Conv Shudder: flushed transmission, replaced filter and tube seal, then road test.
During transmission diagnosis - noticed rear differential leaking fluid. Replaced ALL seal, axle shaft oil as per TSB 385 WP40. Axle seals leaking, R&R Rear Diff & replaced axle seals.
The service manager told me the rear axel leak was causing the vibration. He also said they replaced the torque converter? I never found that in any of my paperwork...
regardless of their stupidity, the NAG-1 transmission is the same as the 722.6 transmission on the mercedes e class cars including the older amg models. those transmissions are just known to have problems. you can find many cases of the older E55 AMG models having blown trannys because the tranny couldnt keep up with the massive amount of torque produced by the supercharger. plus the whole computer for the tranny is under the shift gate so if you have drinks in your cup holders then hold onto them really tightly cause if it spills its gone. i sprayed windex on my shift gate fairly lightly so i could clean it up and make it looks nice and the next thing i know im driving the car in 2nd gear to the dealership with a pen jabbed into the gear shifter. its a poorly designed transmission and i dont think dodge shoulda have inherited that transmission from mercedes cause they were fine as it was. you could dump a big gulp into the tranny of an older dodge truck and it would run fine. magnums are fun cars to drive, but if youre planning on getting one then heed the transmission warning
Amalan - Keep in mind that I am not saying they are not problematic, I am posting up findings on actual information from nonbiased sources to help him make up his mind. When I see sources like NHTSA and other safety organizations have nothing posted on the issue it makes me question what is really happening. Here is another resource with valuable recall information
http://www.motortrend.com/cars/2007/dodge/magnum/recalls/
NHTSA Campaign ID Number: 06V341000 - Hide Details
Recall Date: 09/07/2006
Component: 2007 DODGE MAGNUM POWER TRAIN:AUTOMATIC TRANSMISSION
Potential Units Affected: 2333
Summary:
ON CERTAIN PASSENGER AND SPORT UTILITY VEHICLES AND PICKUP TRUCKS EQUIPPED WITH AUTOMATIC TRANSMISSIONS, THE SOFTWARE PROGRAMMED INTO THE POWERTRAIN CONTROL MODULE CAN CAUSE A MOMENTARY LOCK UP OF THE DRIVE WHEELS IF THE VEHICLE IS TRAVELING OVER 40 MPH AND THE OPERATOR SHIFTS FROM DRIVE TO NEUTRAL AND BACK TO DRIVE.
Consequence:
IF THE DRIVE WHEELS LOCKED UP, LOSS OF VEHICLE CONTROL COULD OCCUR INCREASING THE RISK OF A CRASH.
Remedy:
DEALERS WILL REPROGRAM THE POWERTRAIN CONTROL MODULE FREE OF CHARGE. THE RECALL BEGAN ON OCTOBER 2, 2006. OWNERS MAY CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes: DODGE MAGNUM F43
NHTSA Campaign ID Number: 06V493000 - Hide Details
Recall Date: 12/29/2006
Component: 2007 DODGE MAGNUM SERVICE BRAKES, HYDRAULIC:ANTILOCK:CONTROL UNIT/MODULE
Potential Units Affected: 50665
Summary:
ON CERTAIN VEHICLES, THE ANTILOCK BRAKE SYSTEM (ABS) CONTROL MODULE SOFTWARE MAY CAUSE THE REAR BRAKES TO LOCK UP DURING CERTAIN BRAKING CONDITIONS.
Consequence:
THIS COULD RESULT IN A LOSS OF VEHICLE CONTROL AND CAUSE A CRASH WITHOUT WARNING.
Remedy:
DEALERS WILL REPROGRAM THE ABS ELECTRONIC CONTROL UNIT. THE RECALL BEGAN ON FEBRUARY 19, 2007. OWNERS MAY CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes: DODGE MAGNUM F50
http://www.carcomplaints.com/Dodge/Magnum/2005/
2k6 Dodge Ram 2500...CUMMINS POWERED - SOLD
