1 of 2 subs work
Greetings, I'm new here!
As of now, I'm only running one sub which sounds good but I miss the other one. I've been haveing this issue for quite some time. I tested both subs individually and they both work fine. But when I try to connect both subs, it sounds distorted(EDIT: Both subs sound distorted). I also tried biwirering from the Power Acoustik's amp and it still sounded distorted. any idea's about what could cause this to happen. Here's my setup:
red= power
yellow= remote wire
black with blue circle at end= ground(everything is grounded properly)
black with red and white connects= RCA cables
Orange= speaker wires
I've been haveing this issue for quite some time. I tested both subs individually and they both work fine. But when I try to connect both subs, it sounds distorted. Here's my setup:
exactly what amp are you using, is it mono or 2ch., model number ext. by that picture I'm seeing that you need to have both RCA wires plugged into the amp. get rid of that connector on your RCA's to your amp. thats why its distorted. the RCA's are right and left. You have IE. the left cable on an adapter then plugging into the amp it's going into the Left and Right input.
see if that does anything
1992 Cadillac SeVille STS
Pioneer DEH-P7600MD
Pioneer Premier Surround
JL Audio 10W7 Ported
Kenwood KAC-7203
Kicker ZX350x4
My YouTube
PS2-1600
This is all I could find:
Product MPN
MPN: ps2-1600
Key Features
Amplifier Type: Dual Channel
Bridgable: Bridgable
RMS Power at 4 Ohms: 310 W x 2
RMS Power at 2 Ohms: 370 W x 2
Performance
Frequency Response: 10 Hz - 30000 Hz
Signal to Noise Ratio: 97 dB
THD at Rated RMS Power: 0.02 %
Crossover / Equalizer
Bass Boost: With Bass Boost
Bass Boost Frequency: 40 Hz
Low - Pass Frequency: 40 Hz - 120 Hz
High - Pass Frequency: 150 Hz - 1500 Hz
From this picture it appears to be Mono:
The tripped out thing is I've had this setup since 05' with the same setup and the subs use to work together. I'll still try it out and post the results.
I tried it, but I got the same results unfortunately. Any other idea's.
I'd just take it up to a local car audio store. Like around here there's a couple like "street sounds" and "audio plus". Some places will test you shit. Like you just bring the amp in and they charge a few bucks, same with your woofers. But I would just ask someone to come out and take a look at it.
When you ask them for advise just make it look like your gonna be spending your money with them to fix it if there is a problem.
Pioneer DEH-P7600MD
Kenwood KAC-7203
Kicker ZX350x4
My YouTube
idk if i missed it what subs do you have and what coils
lol. but i haven't and i don't plan on it. plus i'd probably miss and hit her belly button or her ear or something. lol.
  • Who's Online   0 Members, 0 Anonymous, 463 Guests (See full list)
