You could make a custom metal rack. That would allow you to use some kinda thick metal tube and plates plus heavy duty bolts (don't break the amp ;) ). It shouldn't be expensive if you know how to weld decently.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
Dont know how to weld.
i've seen it done with number 10s... shouldn' be that bad
They just seemed like they were way too weak. Not at short lenghts but at a foot long they seem weak.
Hey I wanted to stack my amps (saz 2000) 3 high. It seems that the only size all-thread that fits in the screw holes is the #10 bolts. But these seem way to flimsy. Is there a better way to do it? I wanted something like this. http://www.sundownaudio.com/index.php/ride...hannon-lee.html Any ideas will help. Wanna do this tomorrow.
It looked like they used allthread and some pipe as spacers and to add a little stability to it too.
88-98 GM Full Size Forum www.GMT400.com
i put fuses on power wires, and condoms on fuses, to keep the fuses safe!
I don't know anything about all thread or how strong it is. What I do know is that even if it feels weak to you, you have to remember that is only one of 4 rods that will support the amps, and not only that, but the amps themselves will act as braces. It'll work like scaffolding. I wouldn't worry at all. Try it out and see. If you determine it is too weak after you try, then you should worry about another way of doing it.
My Youtube Page. Check it out
The "SAV" - Sub-aural Assault Vehicle
Kenwood eXcelon KDC-X993
Image Dynamics CTX 6.5" Components
Q-logic 6.5" kick pods
CDT 6.5" CL-E6NEO Front door Midbass
Kicker ZX350.4
Knukonceptz SS Karma 4 channel 6m RCA
Fi Q 18" w/ brushed aluminum dust cap
7cu ft. ported box tuned to 28hz
Sundown SAZ-1000D
Iraggi 240 amp Amputator Alt
Big 3 in Monster 1/0awg
Second Skin Damplifier Lite on roof and front doors
Cool. You guys thinkg they'll be fine if they are stacked directly on each other with no spacing? As the heatsinks are on the sides.
  • Who's Online   0 Members, 0 Anonymous, 1611 Guests (See full list)
