OBI Posted November 14, 2009 Report Posted November 14, 2009 Hey I wanted to stack my amps (saz 2000) 3 high. It seems that the only size all-thread that fits in the screw holes is the #10 bolts. But these seem way to flimsy. Is there a better way to do it? I wanted something like this. http://www.sundownaudio.com/index.php/ride...hannon-lee.html Any ideas will help. Wanna do this tomorrow. Quote
1992Chevy K1500 Posted November 14, 2009 Report Posted November 14, 2009 You could make a custom metal rack. That would allow you to use some kinda thick metal tube and plates plus heavy duty bolts (don't break the amp ). It shouldn't be expensive if you know how to weld decently. Quote My comp setup (Not bad for what it is): HP Compaq Presario V6120US laptop with: 15.4" widescreen AMD Turion 64 X2 1.6GHz processor 2x1GB stick DDR2 SDRAM (667 Mhz) Seagate Momentus 500GB SATA HDD 128MB shared video memory Windows 7 Home Premium 64 bit 12 cell Lithium Ion battery (actual battery usage time: 6 hours) What it does: On a USB 2.0 Wireless card
treossi Posted November 14, 2009 Report Posted November 14, 2009 i've seen it done with number 10s... shouldn' be that bad Quote Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
OBI Posted November 14, 2009 Author Report Posted November 14, 2009 You could make a custom metal rack. That would allow you to use some kinda thick metal tube and plates plus heavy duty bolts (don't break the amp ). It shouldn't be expensive if you know how to weld decently. Dont know how to weld. i've seen it done with number 10s... shouldn' be that bad They just seemed like they were way too weak. Not at short lenghts but at a foot long they seem weak. Quote
Bumpindemlowzz Posted November 14, 2009 Report Posted November 14, 2009 You could cut a slot about the width of a sawblade into 2x4's or simular so the amps feet will slide into them. Quote 2010 Silverado 18" DC XL 18 DC 2k XS Power Batts
cookiemonster Posted November 21, 2009 Report Posted November 21, 2009 All thread worked great for my application. I had 2 3500's mounted to the box face. If you are stacking them horizontally, it should work even better. Quote 1989 Honda Civic 1990 Honda Crx Refs: Sundownz, Derrick824, QCguy
CodyB Posted November 21, 2009 Report Posted November 21, 2009 Hey I wanted to stack my amps (saz 2000) 3 high. It seems that the only size all-thread that fits in the screw holes is the #10 bolts. But these seem way to flimsy. Is there a better way to do it? I wanted something like this. http://www.sundownaudio.com/index.php/ride...hannon-lee.html Any ideas will help. Wanna do this tomorrow. It looked like they used allthread and some pipe as spacers and to add a little stability to it too. Quote 88-98 GM Full Size Forum www.GMT400.com i put fuses on power wires, and condoms on fuses, to keep the fuses safe!
Nirvalica Posted November 22, 2009 Report Posted November 22, 2009 I don't know anything about all thread or how strong it is. What I do know is that even if it feels weak to you, you have to remember that is only one of 4 rods that will support the amps, and not only that, but the amps themselves will act as braces. It'll work like scaffolding. I wouldn't worry at all. Try it out and see. If you determine it is too weak after you try, then you should worry about another way of doing it. Quote My Youtube Page. Check it out The "SAV" - Sub-aural Assault Vehicle Kenwood eXcelon KDC-X993 Image Dynamics CTX 6.5" Components Q-logic 6.5" kick pods CDT 6.5" CL-E6NEO Front door Midbass Kicker ZX350.4 Knukonceptz SS Karma 4 channel 6m RCA Fi Q 18" w/ brushed aluminum dust cap 7cu ft. ported box tuned to 28hz Sundown SAZ-1000D Iraggi 240 amp Amputator Alt Big 3 in Monster 1/0awg Second Skin Damplifier Lite on roof and front doors
OBI Posted November 23, 2009 Author Report Posted November 23, 2009 Cool. You guys thinkg they'll be fine if they are stacked directly on each other with no spacing? As the heatsinks are on the sides. Quote
CodyB Posted November 23, 2009 Report Posted November 23, 2009 Id give em a little room, at least if they do move they wont scratch each other. Quote 88-98 GM Full Size Forum www.GMT400.com i put fuses on power wires, and condoms on fuses, to keep the fuses safe!
