i got to 18 inch aq hdc3 18 2ohm copper coils and i am wondering how big to make the box. i am going to buy two MB quart dsc 2000.1 for 270 each and strap them. and two deka 9g31 battery's for 180 each. these r the specs i have now. 1 inch mdf, H 22inchs , W 49 inchs , D 26 inchs. port size H 20 inchs , L 15 inch , W 6 inchs . i really do not want to go any tall but can make it longer if it is not enough room for the subs and i use the12volt.com to do the tuning and i think it is off i want like 35-38 it is going in the back of a expedition :mellow:
Whip:2004 Ford Expedition
Headuint:Pioneer AVH-P4200DVD
Alt:MechMan 270 Amp
Big 3: Yes
Rear batts:2x Kinetik HC2400
Power Wire:carolprene 0/2 welding wire
Volt Meter:X Scorpion
Front stage:Kicker KS6502
Rear stage:Polk audio 6x8s
High Amp:Boston acoustic GT-4100
Sub stage:Audio Que HDC3 18s Copper Coils D2
Low Amp:Audiopipe AP30001D
Box:6ft3 96in2 34hz
146.8 dbs @ 35hz Sealed up
o ya the top of the box is going to be two sheets of wood so the box is going to be 23inch tall
Alt:MechMan 270 Amp
Big 3: Yes
Box:6ft3 96in2 34hz
User on here made a really good box calculator, ExpoSport. Or you can use RE's box calculator but you have to account for sub displacement, 45s, and bracing yourself
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
holey shit you guys responded fast what is a good amount of room for them and dose any one know the displacement of the basket and magnet what progarm is good to do the port and size shit . and please do not give me crap i am only 16 and this is my second system.
Alt:MechMan 270 Amp
Big 3: Yes
Box:6ft3 96in2 34hz
with 2k rms to each id look at about 6.5 cubes each and 200ish sq in port
Edited by Accordman
good box calculator like web site or how to get to one free
Alt:MechMan 270 Amp
Big 3: Yes
Box:6ft3 96in2 34hz
6 cubes net is a good all around box. Tune 36-38hz.
Thats straight from the man at AQ. I emailed about this a week ago. He recommends 16 sq in per cube so you need a box 12 cubes berore port and sub displacement and 192 sq in of port. With the dimensions you have up there you are working with 13 cubes gross. The port is going to take up 2.3 cubic feet. Thats a 19 x 10 inch sq port 19 in long, I allowed for 3/4" port walls. Then you need to remove area for displacement. Dont have a number for that but could assume .25 to .35 for each woofer.
Your already down to 10.5 to 10.75 net cubes for the box. You might get away with that but you might want to see if you can find some more space.
Im building a box for my Ex cab Chevy for those same woofers with the alum coils.
