Pauliesnite93 Posted November 14, 2009 Report Posted November 14, 2009 dose the MB Quarts DSC 2000.1 do what it is rated and what volt is it rated at.is it a good amp for 265.00 shiped off of Ebay.com Quote Whip:2004 Ford Expedition Headuint:Pioneer AVH-P4200DVD Alt:MechMan 270 Amp Big 3: Yes Rear batts:2x Kinetik HC2400 Power Wire:carolprene 0/2 welding wire Volt Meter:X Scorpion Front stage:Kicker KS6502 Rear stage:Polk audio 6x8s High Amp:Boston acoustic GT-4100 Sub stage:Audio Que HDC3 18s Copper Coils D2 Low Amp:Audiopipe AP30001D Box:6ft3 96in2 34hz 146.8 dbs @ 35hz Sealed up
corrie32 Posted November 14, 2009 Report Posted November 14, 2009 that amp is underated and it's rated at 14.4 volts at 2009-11-04 Quote i love this sh--t man 1966 Ford Fairlane Pioneer prs 80, the big three, with 2 big azz agm batts, dual 270/200 amp alts , two 8'' mids and tweets in the kick( PPI phantom 600.2). two 10''s and tweets in the doors, two 10'' mids and tweets in the rear decK ( Lanar opti 500x2). 2 C2 Audio Threatcon 4 12s on a Crunch GP3000d. No crossover .
Pauliesnite93 Posted November 15, 2009 Author Report Posted November 15, 2009 do u think that one two a aq hdc3 18 copper coils @ 1 ohm would work because they run the aq 2200 two one Quote Whip:2004 Ford Expedition Headuint:Pioneer AVH-P4200DVD Alt:MechMan 270 Amp Big 3: Yes Rear batts:2x Kinetik HC2400 Power Wire:carolprene 0/2 welding wire Volt Meter:X Scorpion Front stage:Kicker KS6502 Rear stage:Polk audio 6x8s High Amp:Boston acoustic GT-4100 Sub stage:Audio Que HDC3 18s Copper Coils D2 Low Amp:Audiopipe AP30001D Box:6ft3 96in2 34hz 146.8 dbs @ 35hz Sealed up
CaptainzPlanetz Posted November 15, 2009 Report Posted November 15, 2009 I would think it would work, the only thing I would do though is try and build the box on the larger side of specs, and make sure your electrical is up to par, IIRC the MB Quarts Discus amps are Class A/B so they are pretty power hungry. Quote ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
Decaf Posted November 15, 2009 Report Posted November 15, 2009 DSC450 4-Channel 400-Watts RMS A/B Class DSC480 4-Channel 640-Watts RMS A/B Class DSC4125 4-Channel 1000-Watts RMS A/B Class DSC280 2-Channel 320-Watts RMS A/B Class DSC2150 2-Channel 600-Watts RMS A/B Class DSC500.1 Mono 500-Watts RMS A/B Class DSC1000.1 Mono 1000-Watts RMS A/B Class DSC1500.1D Mono 1500-Watts RMS D-Class DSC2000.1D Mono 2000-Watts RMS D-Class Quote
Bigg Boy Posted November 15, 2009 Report Posted November 15, 2009 2250ish is what I think some one got out of one Quote Dodge Magnum with custom 300c front end, laid out on air bags *4) 12" Cadence Daytona walled *1) AudioQue 20k *270a DC Power Alt (Dual coming soon)
CaptainzPlanetz Posted November 15, 2009 Report Posted November 15, 2009 DSC450 4-Channel 400-Watts RMS A/B Class DSC480 4-Channel 640-Watts RMS A/B Class DSC4125 4-Channel 1000-Watts RMS A/B Class DSC280 2-Channel 320-Watts RMS A/B Class DSC2150 2-Channel 600-Watts RMS A/B Class DSC500.1 Mono 500-Watts RMS A/B Class DSC1000.1 Mono 1000-Watts RMS A/B Class DSC1500.1D Mono 1500-Watts RMS D-Class DSC2000.1D Mono 2000-Watts RMS D-Class Thank you for pointing that out Decaf LOL, my buddy has a few of the DSC1000.1's and they are A/B, I guess it is smart for MB Quart to switch over to Class D in this case, it would be a major current hog to have a 2000rms A/B amp. Quote ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
Pauliesnite93 Posted November 15, 2009 Author Report Posted November 15, 2009 i was thinking one run of 0 gauge, two deka intimidator 9g31 and two of them amps strapped ,to run two aq hdc3 18s copper coils, big three in o gauge, and porb. a alt later down the road. all in a expedition screw tahoes Quote Whip:2004 Ford Expedition Headuint:Pioneer AVH-P4200DVD Alt:MechMan 270 Amp Big 3: Yes Rear batts:2x Kinetik HC2400 Power Wire:carolprene 0/2 welding wire Volt Meter:X Scorpion Front stage:Kicker KS6502 Rear stage:Polk audio 6x8s High Amp:Boston acoustic GT-4100 Sub stage:Audio Que HDC3 18s Copper Coils D2 Low Amp:Audiopipe AP30001D Box:6ft3 96in2 34hz 146.8 dbs @ 35hz Sealed up
