sabor Posted November 16, 2009 Report Posted November 16, 2009 Ok well, if I had bad batteries, I dont think I would of made it home running my truck off of my 2 d3100s, that where at 11.97 volts once I pulled in my drive way. As for an alternator that costs almost $600, Im referring to your 300 amp CS 144 I bought, that was reliable I guess, but didnt come close to claimed output. What kinda idle output did you get from your Iraggi Alt???????????
Stephen Posted November 16, 2009 Report Posted November 16, 2009 What kinda idle output did you get from your Iraggi Alt??????????? IIRC it was around 235 amps from the "300" amp you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
sabor Posted November 16, 2009 Report Posted November 16, 2009 IIRC it was around 235 amps from the "300" amp That's pretty darn good, right?
Iraggi Alternator Posted November 16, 2009 Report Posted November 16, 2009 If your 300 amp Iraggi did indeed do only 235 amps you must have got the 220 by mistake. I would have had no problem whatsoever getting the correct alt to you if I had known. Do you still have the alt? The external regulator is not needed unless you want to be able to adjust your voltage high. That would save you $100.00 Have you seen the vid of our 300 amp alt? Its the same as when you purchased yours.
Iraggi Alternator Posted November 16, 2009 Report Posted November 16, 2009 That $600 price tag is a little misleading. You got the $99 external regulator. How much is an MLA? I assumed it was $139 or something. Have no idea tho. The external regulator is way better than an MLA. Dom
sabor Posted November 16, 2009 Report Posted November 16, 2009 If your 300 amp Iraggi did indeed do only 235 amps you must have got the 220 by mistake. I would have had no problem whatsoever getting the correct alt to you if I had known. Do you still have the alt?The external regulator is not needed unless you want to be able to adjust your voltage high. That would save you $100.00 Have you seen the vid of our 300 amp alt? Its the same as when you purchased yours. Ok, I'm kinda confused now. I asked what the 300 amp alt did at idle and he said 235. Is the 300 alt supposed to do 300 at IDLE ?
Stephen Posted November 16, 2009 Report Posted November 16, 2009 Is the 300 alt supposed to do 300 at IDLE ? no LOL you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
zfrerichs Posted November 16, 2009 Report Posted November 16, 2009 I have had zero problems with my iraggi alt I've been running it for almost a year now Roseville, CA
Iraggi Alternator Posted November 16, 2009 Report Posted November 16, 2009 It is electrically impossible for an alt to have the same idle output and max output being the same number. When people refer to a 300 amp alt or a 220 amp alt or any amperage they are talking about max. Dom
Iraggi Alternator Posted November 16, 2009 Report Posted November 16, 2009 I have had zero problems with my iraggi alt I've been running it for almost a year now
