ok so i have an Alpine mrp-m1000 hooked up to an MTX 9500 12", the power wire is 4ga and the speaker wire is 8ga, i have a big 3 done with 2ga and stock alt and battery and the deck is a Pioneer deh-p5900ib all connections are good and everything is hooked up right. now my problem is, i will be bumpin it for a while and it will sound good but then the amp gets really hot and cuts out to about half power and i have to let it cool down before it will work right again
any ideas?
Ascendant Audio Havoc 15 D1
4.5 cubes tuned LOW...28hz
Alpine MRP-M1000
Front Stage: Infinity Reference 5 1/5
Rear: Infinity Reference 6x9
Alpine CDA-117 with power pack
240a DC Power alt
Big 3 in 2ga.
97 Monte Carlo(R.I.P.)
he either has it at 4 or 2ohms so it shouldn't mess with the amp. i'm thinking it's where he has the amp sitting maybe?
"i'd rather die like a man than live like a coward" quoted from Tupac
damn i knew i was forgetting something lol it dual 4 wired at 2
Alpine MRP-M1000
240a DC Power alt
Big 3 in 2ga.
what do you have the gain on your amp set at? sinnce your running a 5v pre amp you should have your amp gain set no higher than 1/4 of the way up.
its mounted to my back seat and i ALWAYS have them folded down when im bumpin
Alpine MRP-M1000
240a DC Power alt
Big 3 in 2ga.
check to see if you have a good ground too. make sure all the paint is removed from the mounting location also
I see don't know much about his woofer so I was wondering. I've had three of the apline MRP modles the 800 or 850 I think and the 650's both the 650's would do this. Everthing hooked up right and set right running at two ohms. Never figured it out ended up upgrading to a bigger amp. Good luck Ill keep reading to see if I find anything for ya.
these are my amp settings:
this is where it sits:
and this is how hot it gets...
its been in the same place since i got it, its been tuned the same since i first got it, and it just started doing this like a week or two ago
Alpine MRP-M1000
240a DC Power alt
Big 3 in 2ga.
  • Who's Online   0 Members, 0 Anonymous, 685 Guests (See full list)
