GetLikeMe's 4 SA-12's / 3500D Build
very nice.
i think you should turn it around for sure with the back of it all the way against the back of the trunk, at least try it out before you think about rebuilding
and after watching the vid i can see a place for your 3500D. off to the right of the box. looks like you could fit both amps over there (opposite side of the batteries)
Ya it will be a pain to move since my 0gauge is already cut the length where its at now lol.. Id need another piece thats about 8ft to move it over there.. I kinda wantd a single setup anyways just got killer deal on these 4 subs so thought id give it a try lol
Team Bass-Hz
you should be able to reach it if you run the wire from the buss bar, under the box. (just straight across the trunk)
how much are you looking to get for these?
I really think that you should try flipping that box around. Just sit the 3500 on the back seat to test the box in the other direction. If it works out for you then you can worry about where your gonna put the amp. If it were me and it works flipping the box around I'd mount the amp on the back of the box so it's there right when you pop the trunk open. All you would need is a bit more 0 guage and it would be well worth it if you flip that bish around and it's 3-4db's louder. Listen man!!!
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
