T3audio/Atomic/ Navigator Re-Build 7kw(BIG UPDATES PG 38-
alright so the scoop on this thing is that its not that its super loud but it will play EVERYTHING!
literally he didn't have his iPod so I sat there on BigPimpin's playlist throwin sweeps at it, lows, highs any where in between and it smashed it.
sounds like a tin can which he thought was his roof until I looked outside and it was his door slappin against the frame.
it got smelly once but that was before we got everything figured out between my iPod and his deck volume wise but after that slammin for days and nothing got too hot.
still a few little things to work out.. VOLTAGE!
but otherwise I hated going back to my car... nice and quiet deadened :D
I also had the BassBooster EQ on my iPod off for his just like Loganberry's but I have my system tuned to have it on so I forgot to turn it on and really thought mine was that much quieter I was pissed until I realized it haha
Wouldnt be thehoe92 without teh purple
when he was over here and I was checking the wiring to the subs (wired way wrong) I noticed there was another ringing inside the truck towards the box, when he hits a certain frequency, it rattles the frame
Someone help out homeboy with some gaskets!!!
You need woofer gaskets man, I have 2 myself, but I need to use them on woofers for sale
Actually Navi, hit up Jacob, I'am sure he will hook you up for a good price on gaskets
I told him wire positive to negative on one of the coils on both subs then wire the remaining wires together and out to the amp
like that maybe what I said was mis translated in text haha
but yeah this thing definitely has potential :good:
no"im pretty sure" it was wired up like that
BUILDLOG
http://www.stevemeadedesigns.com/board/ind...showtopic=61862
"98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!!
Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
thats how I had it in the elvis box... I think you should wire it down to .5 :spiteful:
it was wired up like that..
but .5 idk this week come over and we can try if u want we can do some tests...even tomorrow if u want i know you dont have school
BUILDLOG
^ was not wired up like that AT ALL
one coil was being used, the other coil was shorted to itself, both subs like that
its ended up at 1ohm ser/parr
used a volt meter, and checked amperage after wired up
But what was happening, the coil that was shorted to itself was causing the coil to over heat, and when the coil is shorted to itself like that, its causing the coil to stay stil in its own magnetic field, while the other coil was working- yes it was wired at 0.5 ohms when he rolled by, but completely done wrong
tell me how you get 2 subs, Dual 1ohm wired to 0.5 ohms? these subs are D1, not D2
hmm strange i left it the way kasey did it last time it was all wrapped up with tape as u seen.... u were the one to cut the tape off with the scalp
BUILDLOG
HE LIES THEN!
haha he told me dual 2 so I went and looked up that little diagram but never thought to check them
if both are dual 1 then he's cool at 1 ohm no need to fuck with it
and minel I have a 18" gasket from my BL that I took off to get a better seal on my tline
