is 155.1 db ok for about 5K watts
see they told me it was 155 in dash and kicks
i did 152.8 in the kick on a a/c mic an 147.3 sealed up @ windshield termlab an 147.9 in kick panel on term lab @ 32 hertz wished i would been 150 :(
good number tho bro,also sweet setup shits beatin
Still looks intense. but I wouldn't advertise .5 ohm. They'll do it, but if it blows it wouldnt be covered under warranty. Good luck though and No Steve...no shops left and those that are pretty shady, but then again they have to be when in competition with the internets.
well i know its hittin hard,, i see the destruction everywhere on my yukon,,i never was into the numbers,,more of the freakshow,,,the shock factor,,,but now im curious
also,, none of the gains have been set on a volt meter,,so would that gain any thing.. and what else can a person do to gain more db an still keep the factory look inside
sound deadener....maybe? there have been time when compettitirs lose #'s after deadening. get rid of all fabric and replace with vynil, headliner etc make sur heater ac vents are all closed turnd off when testing remove headrests recline seats take off all panels seal all metal pocets with foam/fiberglass and put panels back on.
http://www.stevemeadedesigns.com/board/ind...showtopic=29213 "sleeper build"
(1) DC AUDIO Level4XL 10
(2) PowermasterD2700 batteries
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
the whole truck is done in dynamat extreme,,,and interior is leather
even the headliner is it suede or hard leather. basically any carpet or fabric absorbs sound waves so the more "reflctive" you can make it the better. also if you dont plan on running in anything but mod classes at comps you could always seal up the underside of the dash so the soundwaves dont get trapped there
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
no, the headliner is stock,,,but i see what your sayin..how do you seal up under dash,,,im going to be adding two more AQ2200s,,and four K 2400 batts,,will that help some
add more power wire from the front to the back aswell
R.I.P!
(Nov-29-2009)
92 explorer
current build
i think 16 cubes,, 200sq inch of port,,,said it was tuned to around 34 hrtz
That seems pretty small for 4 18" HDC3s, especially off "only" 1500w or less per woofer.
Just spoke with a guy there.
B&K Meter
155 on dash sealed
151 in kick sealed
he said the meter may be off up to 3db
WITH THAT SAID
at worst you are a 152.1 which is still pretty damn good off 5-6K
I live right in the middle of tulsa, was the place that messed it all up Boomers audio?
I've seen B&K meters be off by as much as 3-6dbs so I wouldn't say "at worst he'd do a 152.1"
yeah... u can say thats a decent score on 5k rms
I agree it's a pretty decent score on 5-6k watts but with that much cone area I'd expect at least that.
thats the first time i ever saw someone LOSE 4db in the kick LOL! I usually gain 1.5 and some people GAIN 4. Never lose - anyway, sorry your having issues bro damn......is there ANY good shops left these days?
There really are very few quality shops around now that actually take pride in their work and it's actually pretty sad... I'm also SHOCKED that any "regular" vehicle would lose that much going from dash to kick. Obviously it will happen with purpose built SPL vehicles that are built to meter at the dash but never seen a regular setup change that much.
That just sounds really suspect and seems like they just rushed through the metering session. I'd try to find someone local to you with a TL or any official comps that you can make a few runs through.
i got about 25 feet of 4/0 im going to put in,,is that good
Personally I would have done 2 runs of power/ground per amp with 1/0 or 2/0... What other electrical upgrades do u currently have??
Did the shop set your gains by ear or did you set them yourself?? You can definitely increase your score by having correctly set up gains and plus be running the amps "cleaner" and more efficiently. Also with a different enclosure I could almost guarantee you would see a gain over the current one you have.
Pioneer AVIC-N2
  • Who's Online   0 Members, 0 Anonymous, 1273 Guests (See full list)
