Betsy Gets Bass Finally
No pics with that black cover piece off tho? I know the general area where its gunna go but I cant see the exact spot. If not its cool, Ill figure it out when I get under the car n peep out the other side
naw, i didnt because it was sunset then so not light and my cameras flash sucks balllllz
maybe tomorrow i can take a pic, its obvious tho when u get a light in the engine bay shinning down and u crawl under the dash
Cool, Sorry for all the questions n shit. Jus wanna make sure I do shit right the 1st time
Rebuild in progress...
dont be sorry, i searched all throughout cadillac forums to find all the answers to my questions
including removing the dash, rear deck, location for ground, location for firewall hole.. and for wiring schematics
check it out sometime, its pretty sweet that so many people have our old azz caddys
Hey man dont worry about them pics. The ones you gave me helpd me out enough to figure out a spot. Pretty sure its different than yours but it'll do. Again thanks for all ur help. Jus got my amp today... FI tracking # said the sub was supposed to be here today to but it aint? I'll start my own topic n quit whoren it up on urs!!!
Ok another question. I seen in another post that you said it wasnt good to mount an amp upside down. Well I was reading the AQ manual and it said somethin about it working well vertically. What do you think about mounting the amp to the metal behind the backseats? Id give it room to breath with nuts and bolts. Pry some rubber bushings to???
upside down and vertical are different
mounting the amp on the backseat will be just fine if u secure it well
some seats just have cheap plastic, some metal so depends on ur seat
i like mounting flat because then both sides of mosfets can disipate heat straight up... if u mount it on a back seat 1/2 the mosfets disipate some heat thru the entire amp and out the top heatsink.... which in my mind heats up the upper mosfets more than the lower... maybe im thinking to much about it tho... but i keep mine flat as much as possible to reduce heat
its easier to travel thru 2" of metal than 9"
  • 2 months later...
small update... tryin to keep the trunk from falling apart so i spent $20 on peel&seal and great stuff
rear deck moves waay too much, this kinda helpes... need another layer
2 layers thick
perfect amount of great stuff, just barely oozin out
used the rest of the roll here, not easy when ur box is in the way, its too heavy for me to move by myself
try to take a vid while it was drying and i had the trunk open but the car next to me had a sensitive alarm on i guess
song is "Eldorado Redd - Flexed Up (30hz)"
might buy another can and roll, but thats about it
Nice! Did that deadner help at all? My second skin workd to damn well. Might switch it up to 2 SA12's in the near future! That rear deck doesnt look to bad with the light off of it tho. I might have to take mine off and get rid of that storage compartment back there to. But I dont wanna leave it bare metal. And Im not skilld enough to make a decent looking beauty panel so idk, But I do need more air in my cabin somehow!
yeah the $14 worked great, as usual
second skin is way better but i just needed something to help that was cheap
the great stuff helpd alot too
it looks nice without the rear light personally... i did it moreso because it was bouncin
my major problem is gonna be the trunk latch, its mounted to a bracket thats mounted to sheet metal, no bracing... so needless to say i need to do some reinforcing otherwise the trunk latch is gonna break, this car was not meant for bass at all!!!
so i took my amp and sub out... im building an amp rack thats connected to a big board that the box will sit on so it doesnt move around in my trunk, ill get pics on a few... i can also easily add a battery now too and just add a little piece of wood next to the amp
hopefully switching things up will get me to buying a new/another batt, i need one really bad
new amp board and sub floor (1/3 of it at least)
lots of left extra wire for the next install whenever that is
straight down thru the hole in rear deck
looking to left down thru the hole i made in the rear deck
to the right thru the hole
gain setting u can see is at ~1/4 and it slams, ssf @20, lfp all the way up (i used -18@100 on headunit), no boost
super chitty trunk lid pull down motor thats duct taped and foamed and welded because it kept breakin... thats mostly why i added deadner and great stuff instead of turning it down
once the box is back in ill really load that motor up with duct tape since the power has been disconnected i just need it to be more stable w/o welding something new
