total port length is 25.75
so u would enter 0 in for "square port length 2"
i just guestimated them to be .3cuft together
but u would divide 243.6 by 1728.... = .14cuft per sub
ok awesome gotcha gonna sketch it up in sketchup real fast
thanks for the help decaf
any ideas on how much bracing I will need?
Alpine CDA-9887
15" FI BL
JBL BP1200.1
Rockford Fosgate p142 4" front
Rockford Fosgate p1S652 6.5" rear
Optima D35 yellow top under hood
Big 3
all in a 1997 Toyota Tercel
I'd just have a couple of like 3/4" or 1" dowels, each on going a different direction.. Like one going the width of the box(try to center then as much as possible, that's where the box will be the most prone to flex), one maybe between the woofer(or as close to being), and one more going the depth of the box. As long as it's calculated into the box design then there is no such thing as overkill for bracing.
Pioneer AVIC-N2
dowel rods take up a negligable amount of airspace so even if u dont account for it together its like .06cuft
follow marlos suggestions, front to back, side to side, top to bottom
and if u can align them so they can be screwed together and act as one brace u have the best possible bracing using dowel rods
ok so I made a mock up out of cardboard and it won't fit in my trunk so i guess building in the trunk isn't an option anymore
what do you guys think of putting them in the back seat? port and subs facing forward
Alpine CDA-9887
15" FI BL
JBL BP1200.1
Big 3
word well I guess I'll try it out and see how it sounds
Alpine CDA-9887
15" FI BL
JBL BP1200.1
Big 3
well I "won't" be able to make a box for m trunk the dimensions aren't enough to work with the biggest mock up I could make was only about 4.5 cubes unless I build the box inside of my trunk lol...The opening of my trunk is only 36"x15"
max width is 36 max height is 15 and depth is 29" if you can come up with something that will fit in that let me know because I didn't get anything close that would work
do you really think it will sound that bad? the cars only a 2 door so theres no real point for the back seats lol
so unless I build the entire box inside my trunk it's mostlikely going in the back :/
Edited by drumminian
Alpine CDA-9887
15" FI BL
JBL BP1200.1
Big 3
  • Who's Online   0 Members, 0 Anonymous, 2930 Guests (See full list)
