Best amp for 15''DD 9500 series?
217DigitalDesign
enclosure is pretty big assuming that's net. AQ2200's or 3500's. Guy on my team runs an AQ3500 of each of his 9518's. They're in 12cubes net...
Lies!
My new box is 21.75 cubed external, and about 16.5 after sub/port displacement and run 3krms per sub.
So by any means a 10 cubed box even if its after sub port displacement is kinda small, especially if he is only looking at 1500wrms per sub.
I agree with boon, 2 db-r refurb sundown saz3000s would do nice!!
As for amps
Sundown
DD
AudioQue
Rockford Fosgate
Stetsom
All quality amps, that Id trust with DD subs.
You want to be sure to give the subs clean output power.
Here is my 21.75 cubed box on 1 3000wrms amp @ .37 Daily (gotta break the subs in before full power).
i say 2 sundown saz 3000ds :hairtrick:
Head unit Pioneer deh-80prs
Sub Amp
Highs Amp Skar audio Lp 60.4
Tweeters and Highs 2 Skar audio fsx 6.5 and 2 spx-t
Subs
Batteries?
alt?
SPECIFICATIONS
Series 9500g
Voice Coil Diameter 3"
Magnet Weight 406 oz
Power Handling RMS/Peak 1500/6000
Suspension 80 mm
Nominal Impedance D .5, D .7, D1.0, D1.5, D2.0, D4.0 Ohm
DC Resistance .5 - 3.6 Ohm
Model 9510g 9512g 9515g 9518g
Rec Box (cubic ft) 1.6 2.6 4.25 6
Port Area (sq in) 26 42 70 100
Port Length (inches) 23 22 21 20
Woofer Diameter 10" 12" 15" 18"
Free Air Resonance
35 Hz 34 Hz 33 Hz 29 Hz
Qts 0.25 0.31 0.29
Qes 0.27 0.33 0.31
Qms 3.1 4.15 4.32
Vas 15L 35L 85L
Sensitivity 87 dB 89 dB 93 dB 94 dB
now this is straight from the DD website, their Rec Box is 4.25 for the 15's and 6 cubes for the 18's i don't know where those big ass boxes specs come from. i guess y'all know something DD don't
i love this sh--t man 1966 Ford Fairlane Pioneer prs 80, the big three, with 2 big azz agm batts, dual 270/200 amp alts , two 8'' mids and tweets in the kick( PPI phantom 600.2). two 10''s and tweets in the doors, two 10'' mids and tweets in the rear decK ( Lanar opti 500x2). 2 C2 Audio Threatcon 4 12s on a Crunch GP3000d. No crossover .
I have 2 15" DigitalDesigns in about a 10Cu.ft. box and i was planning on buying 2 Sundown Audio 1500d's. What are the best kind of amps for DD's?
Replys would be greatly appreciated...
What kind of electrical setup do u have to handle this sort of power?? You're looking at anywhere from 3000w-7000w+ depending on what you're willing to spend. If you're not gonna have the proper electrical to back it up, then it's a waste of money to get tons of power that you can't support. Also what are the coils?? What motor 9500 do u have??
Not knowing any of those questions and just throwing out suggestions in the general power range -
SounDigital 5000.1
American Bass 500.1
(2) Sundown SAZ-3000Ds, refurbs from DB-R or used off the forums
I'm running 2 9515gs in my current setup off of 2 AB VFL400.1 @ 1ohm each.. It is a lot of power for them but I am pretty careful and when/how hard I can push them before bad things might start happening. Also having the extra stiff suspension and kevlar cone help handle the power well.
Pioneer AVIC-N2
Aparently you've never done any sort of competing or have had really loud setup before :01nocomment8so: if you only go by manufacturers rated enclosures. DD's rec. box specs actually are a pretty good starting point for a daily setup but by no means are they the end all specs. They also don't account for if you're running power that is much higher than the rated or much lower either, the box size helps raise/lower efficiency to maximize the power you're using.
Pioneer AVIC-N2
:01nocomment8so: :01nocomment8so: :01nocomment8so: :01nocomment8so: :01nocomment8so: :01nocomment8so: :01nocomment8so: :01nocomment8so: :01nocomment8so: :01nocomment8so: :01nocomment8so: :01nocomment8so: :01nocomment8so: :01nocomment8so: :01nocomment8so: :01nocomment8so: :01nocomment8so: :01nocomment8so: :01nocomment8so: :01nocomment8so:
Oh, and just so you know, those specs listed on the site DO NOT include port, sub, or brace displacement.
[/quote
yes i know that
Aparently i have competed, and i have 2 first place trophies to prove it, and i've had plenty of loud systems,, but to each his own,, it's not like i paid for them. i can't afford those high price subs, but i also don't like to see someone blowing them up. Hate me for being concerned
I think the OP is gone lol... He only has 2 posts and both in this thread, plus he has yet to answer a single question we've asked regarding his setup.
Pioneer AVIC-N2
you don't have to feed that thing 6k. i've seen a guy do a 150 out of a trunk with a 9515 on two SAZ 1500d's strapped
  • Who's Online   0 Members, 0 Anonymous, 731 Guests (See full list)
