durty_riz Posted May 13, 2007 Report Share Posted May 13, 2007 Does anybody know where can i find Solid Audio monoblock amp F2000 specifications.. i have one n some how i lost its manual and i want to wire it up but dont know if its a 2 ohm stable or what ever!! help needed Link to comment Share on other sites More sharing options...
durty_riz Posted May 13, 2007 Author Report Share Posted May 13, 2007 come on guys !!!!!! Link to comment Share on other sites More sharing options...
Herrie_V Posted May 13, 2007 Report Share Posted May 13, 2007 Google is your best friend Link to comment Share on other sites More sharing options...
roscoe1129 Posted May 13, 2007 Report Share Posted May 13, 2007 I used to use Solid amps but I cant even find them on google either, some good stuff for fairly cheap..... Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER Link to comment Share on other sites More sharing options...
durty_riz Posted May 13, 2007 Author Report Share Posted May 13, 2007 so that means its a 2 ohm stable amp right? now if its a 2 ohm stable amp then how should i wire it with my subs as my subs are dual 4 ohm..?? or can i just wire it parallel and bridge both the subs which makes 1 ohm of load if im right... Link to comment Share on other sites More sharing options...
roscoe1129 Posted May 13, 2007 Report Share Posted May 13, 2007 yea wire your subs to two ohms each and then connect one to each output on the amp Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER Link to comment Share on other sites More sharing options...
durty_riz Posted May 13, 2007 Author Report Share Posted May 13, 2007 yea wire your subs to two ohms each and then connect one to each output on the amp that means i should not bridge it just wire them each on a single channel..!! n will it give enough juice to my subs as my subs are 1000wrms each..? Link to comment Share on other sites More sharing options...
roscoe1129 Posted May 13, 2007 Report Share Posted May 13, 2007 it is a 2 channel amp and it puts out 1000w at 2 ohms per channel so do not brige it as it is not 1 ohm stable 1 speaker per output of the amp are your subs 1000w rms or what?? Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER Link to comment Share on other sites More sharing options...
durty_riz Posted May 13, 2007 Author Report Share Posted May 13, 2007 it is a 2 channel amp and it puts out 1000w at 2 ohms per channel so do not brige it as it is not 1 ohm stable 1 speaker per output of the amp are your subs 1000w rms or what?? ermm.. well that explains much ...! then i guess i should stick to 2 ohm ... thanx for the advice people ... one more thing, im confused how to connect my amp to the head unit.. i mean i have two amps Solid audio ms42 600watts 4 channel and F2000 ... which amp should i connect to the HU, F2000 or MS42 ( please remember i also intend to connect a bass knob ) Link to comment Share on other sites More sharing options...
