Solid Audio Specs!
durty_riz
I used to use Solid amps but I cant even find them on google either, some good stuff for fairly cheap.....
Scientia est Vox
SMD SUPER BUYER/SELLER
so that means its a 2 ohm stable amp right? now if its a 2 ohm stable amp then how should i wire it
with my subs as my subs are dual 4 ohm..?? or can i just wire it parallel and bridge both the subs which makes 1 ohm of load if im right...
yea wire your subs to two ohms each and then connect one to each output on the amp
Scientia est Vox
that means i should not bridge it just wire them each on a single channel..!! n will it give enough juice to my subs as my subs are 1000wrms each..?
it is a 2 channel amp and it puts out 1000w at 2 ohms per channel so do not brige it as it is not 1 ohm stable 1 speaker per output of the amp
are your subs 1000w rms or what??
Scientia est Vox
ermm.. well that explains much ...! then i guess i should stick to 2 ohm ... thanx for the advice people :) ...
one more thing, im confused how to connect my amp to the head unit.. i mean i have two amps
Solid audio ms42 600watts 4 channel and F2000 ... which amp should i connect to the HU, F2000 or MS42 ( please remember i also intend to connect a bass knob )
  • Who's Online   1 Member, 0 Anonymous, 630 Guests (See full list)
