Alright summer is basically here and im updating my system to a 15" BL powered by a RF T10001Bd and maybe a RF T4004 pusing my components down the road and im trying to keep the budget kind of low and I know I need to update my electrical system if I run those 2 amps and was wondering what would be better, getting a second battery (Kinetik KHC1400) or get a new alternator which would be a Iraggi "Dominator Series" the puts out 75A Idle/200A???
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
I would recommend starting with a new altinator since you probably wont be banging that shit with the engine off.
I never bang it with the engine off, but thanks for the quick response
2007 Chevy HHR LT
UNDER CONSTRUCTION
but would that alternator provide enough current to push a system like that good?
2007 Chevy HHR LT
UNDER CONSTRUCTION
fosgate reccomends a 150 amp fuse for that amp so I am guessing that a 75 amp idle altinator is going to be a little weak for that amp.....
Scientia est Vox
SMD SUPER BUYER/SELLER
I dont quite understand how alternator ratings work, does 75A idle mean it creates 75A of current when the car is at idle? and is the 200A the max current it can generate, so will I ever see that alterator push 150A to that amp?
2007 Chevy HHR LT
UNDER CONSTRUCTION
correct at Idle the alt is pushing 75 amps of current out of it to run your electrical system, the max your gonna see is while its spinning faster while running down the road at 30+ mph. so unless your gonna be reving your engine all the time (bad idea for the engine) you should get a stronger alt....somewhere around 175 or 200
Scientia est Vox
But the amps never draw that much power to begin with, and its not a constant draw. That's what the battery is there for. The amps drain it, the alt charges it back up. If the amp drew 150 amps the fuse would be blowing. That alt would definately be an improvement.
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
Right I wasnt saying it would be drawing that much current just that a 75 amp alt at idle would be a little weak for his system....sorry for the confusion.
Scientia est Vox
