SPL for SUV
ahoz28
I would like to compete localy at sound offs. I have a 04 GMC Yukon that i have been playing around with. I like to do as much of the work myself to learn and save money, but i dont mind paying for quality work. I have four 15t2 subs, two t40001bd amps and have tried defferent boxes. I would like build something that focuses on the meter.What kind of one note wonder could work in a Yukon? I know i have to test and experiment, but any advise would be cool.
you want to get loud on music or just a burp box?im assumine this is your everyday driver right, not just a competition car? i would go subs up port back. try and tune around 35 htz. how many batteries you have? H/O alternate?
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
Burb box is what i think would be fun to try!
Is it possible to hit over 150 with one 15 in a burb box at the cargo area of a suv?
It is absolutely possible especially with the equiptment you have. I would suggest using both of your T4000's on one sub as well. You'll just have to turn the gains down some so you don't cook your woofer.
I use 1 15 in my spl setup. I don't exactly have an suv but my box works in an Explorer cause I happend to put it in a team member of mine's. It will do over a 153 in my vehicle now with a little over 5K watts. It did a 150.9 in the Expo with right around 3600 watts.
You have way more power than what we were working with and I'd say that you could easily do 153's with the amount of power you have. The only thing that's going to be holding you back some is that sub. Nothing is wrong with it, it's just not great for spl.
I'll give you a place to start and you can go from there. Build a box with 3 cubes after woofer displacement. Get yourself a piece of 8" pvc and flare each end like an aeroport. I can't tell you exactly where to tune the box to cause I don't happen to know the resonant freq of your vehicle, but if I had to guess I'd start out around 37-38 hz. Build the box so it is woofer up and the port external. Then you can try woofer up with the port firing back, to the driver's side, passenger side, woofer foward with the same flipping the port different ways. You see what I'm saying is make the box so it can be flipped around easily so you can find out which way is loudest.
Here's a link to my spl build thread on here of the box that does 153's with 5K watts: http://www.stevemeadedesigns.com/board/ind...showtopic=52678
If you have any more questions let me know. Also just by building that type of box I told you about won't guarantee you an automatic score but you should easily break 150 with your equiptment. The rest of the spl is found my tweeking the vehicle and getting to know what it likes.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
Thanks for the info I knew id seen something like this. I hit 150 with big box @39hz and four 15s, its sounded great on music but i realy want it for the meter. I didnt even want think of a wall because of my noobness. I will try with my 15s before going biger. I received a termlap from a guy in Mooresville, NC ,anywas I guess I have a solid starting point.
Mooresville, I happen to know a pretty big influence in the car audio world that lives in Mooresville. I wonder if you bought his old Term Lab?
1 XS Power D3100
Audio Control LC6i
Stock Deck
Are the nightshade subs a good spl sub?
Yes they are quite good for spl. They are right on par with some of the top spl drivers in the world. I've seen in quite a few cases Nightshades being dropped in over several other brands and people gaining from .1 to even .5 db's. They are what I use for daily and spl. Jacob, the owner of Sundown, uses a single Nightshade in his Jeep and can do over a 154 with it on around 8-9K watts. His prototype spl woofer is capable of over a 155 with the same power.
1 XS Power D3100
Audio Control LC6i
Stock Deck
yea sundown makes some ridiculous stuff. if your planning on just burping and dont care to much about music you want to tune to the loudest freq in your car. since you have a tl i would say just get sub in a sealed box. play the same volume test tones from low freq. to high and the loudest one is the one your car likes the best. tune your box right around there and you should be getting pretty loud. no reson you cant do 150's. im pretty sure some of the loudest setups out there are single subs. install and box desing are the most important part
New Project
[top secret]
  • Who's Online   0 Members, 0 Anonymous, 1989 Guests (See full list)
