first thing i'd do is turn that bass boost down. all the way. then readjust your gain properly. for displacement, depending on size of the box and number of subs, i usually use around .2 ish for each sub, then add a few tenths for bracing displacement. the bigger the box is you build, the more surface area of port you'll need to properly suit the enclosure. general rule of thumb is 12-16 sq inches of port per cubic foot. frequency tuning depends on how much port area you have. less area will require a shorter port length than that of one with more port area in the same box to maintain the same tuning. are you going to be using an aero port? that quote says one 4" port for a 2 cubic foot box. doing a 4 cubic foot box going by those recommendations you'd need two 4" ports. each 10 3/4" long. i havent checked that tuning so i'm assuming it's right.
if you're fully lost, post the dimensions you have to work with and someone can help you with a design
Here's where I'm at so far on the design.
I'm going to go with subs up, slot port facing back.
I have plenty of room in height and length on the truck. No worries there. The width is right at about 46 inches so 44" would be nice and snug.
yo i live pretty close to atlanta i could prolly help you out with gettin this done right
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
u can put um at 1 oHM if ur amp can handle it
yellow optima kicker 0gauge
Alpine CDA-105
4 infinity 6 1/2s - 2 infinity 6x9s
Audio Control Epicenter
1 Hifonics XX Hurcules
8K hid
2 RF HX2 18s D4
sealed at 8cubes
4 now
in a grand cherokee
box build comin soon
sory bout that go to 2 ohms
And X2 on lowering ur BB
Alpine CDA-105
8K hid
2 RF HX2 18s D4
sealed at 8cubes
4 now
in a grand cherokee
I have the punch series.
Here are the specs for the subs. I'll be using two of these.
# dual 4-ohm voice coils
# CONsealer gasket hides mounting screws and prevents air leaks around the frame
# frequency response 26-200 Hz
# power range 150-500 watts RMS (250 watts per voice coil)
# peak power 1,000 watts
# sensitivity 88 dB SPL
# top mount depth 5-13/16"
# sealed box volume 0.8-4.0 cubic feet
# ported box volume 1.75-4.0 cubic feet
Here are the specs for the amp.
# Max power 2-ohm 1000W x 2, RMS power 4-ohm 300W x 2
# Max bridged power 4-ohm x 2000W x 1, signal-to-noise ratio > 102dB, THD 0.01%
# Features remote subwoofer level control, tri-mode operation and bridgeable
# 11 7/8" W x 2 5/8" H x 16 13"/16" L
Right now I have the subs wired up at 4 ohms bridged according to Rockford's diagram.
You think I should drop down to 2 ohms or leave it at 4?
first off that amp will not handle a 1 ohm load . your subs can either be wired @ 1ohm or 4ohm and that amp will go into to protect if you even do a 1ohm load. and why ur subs are going into shit mode is a totally different story. like build quality of the amp . you probably have the gain turned up. way up and and when you give it volume its sending a "2000 Watt" clipped signal and tearing your subs apart. get a better amp before you kill those woofers.
Edited by Tooshort064
95 Civic Coupe
Pioneer AVH-P7600DVD
Kinetik HC-1200 In Front
Kinetik HC-2000 In Rear
Memphis 16-MCA3004
2 X Memphis 16-MCD1000 With Maxxsonics MLX-100
2 X DC LVL 4 XL 12's
Pioneer Premier TS-C720PRS In Door's
Kenwood KFC-6982ie In Rear Deck
All Memphis Wire/Rca's and misc.
  • Who's Online   0 Members, 0 Anonymous, 996 Guests (See full list)
