Mosin Posted November 29, 2009 Report Posted November 29, 2009 I'm looking to replace my mid/high set-up in the rear deck of my GA GT but IDK what to go with.. First off, what has better SQ? Comps or 3-way 'oval' speakers? I want something with decent SQ but I want it to scream pretty loud as well. I was wondering out of these 2 sets, which would be better at doing it for me? Or is there something out there for the same money as these 2 that'll be even better? Kicker KS6930 Kicker KS60.2 They will see amp power, either 75RMS or 150RMS. Haven't decided yet. If I decided comps, would these adapters work? Adapters Derp.
Marlo Stanfield Posted November 29, 2009 Report Posted November 29, 2009 What do u have right now for a front stage?? I'd suggest running the components for sure.. Found these for a little more than u the others, but if they're anything like the previous Power comps then they're well worth the money. Plus they are damn clean and get loud as all hell - http://www.sonicelectronix.com/item_19564_...er+T1652-S.html 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
Mosin Posted November 29, 2009 Author Report Posted November 29, 2009 Infinity Kappa 462.9cfp For the doors Sony Xploded by-9's in the rear. I like them RF's but you think they'll satisfy my want for loud yet decent SQ better than the Kicker's would? Derp.
Marlo Stanfield Posted November 29, 2009 Report Posted November 29, 2009 I'd suggest getting a comps that I had in my last post and putting those up front... Then taking those Infinitys and putting them in back. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
Mosin Posted November 29, 2009 Author Report Posted November 29, 2009 How would that help by putting Infinity's in rear and the Power comps up front? Better SQ or? But you'd bet on comps getting louder than 3-way ovals? Derp.
Marlo Stanfield Posted November 29, 2009 Report Posted November 29, 2009 How would that help by putting Infinity's in rear and the Power comps up front? Better SQ or?But you'd bet on comps getting louder than 3-way ovals? Yes, by mounting the comps in the kicks or the speakers in the doors + tweets in the a-pillars the SQ/output/etc would be much better. Why would u put the better speaker set in the rear of the car when you're driving from the front?? The 6x9s will be more bassy but the comps will likely win in all other categories... The older RF Power comps were incredible IMO for the price and power they needed. Were pretty clear, incredibly loud and were indestructable. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
Mosin Posted November 29, 2009 Author Report Posted November 29, 2009 Seems like a good idea, I just don't wanna modify/cut anything in the doors. Not looking for the perfect SQ set-up. Being as my highest price I could go is roughly $120, what else is there out there that could perform just as well if not better than the Kicker comps? Derp.
