Boon Posted December 2, 2009 Report Share Posted December 2, 2009 it has been done in usaci and has won 2 world titles (spl burp class) This I gotta see... why would a world title-worthy competitor be running only half a DVC sub? It's not like competitors of that caliber can't get gear that matches completely. Who/what/when/prove they only used 1 coil? Unless you mean they burnt a coil mid-burp or something ;/ Quote 10.x volts fo' life! Link to comment Share on other sites More sharing options...
jmanjr82 Posted December 3, 2009 Report Share Posted December 3, 2009 sure his name is sanman on most forums real name is jeff he is the one who told me its fine, and you can check stats on usaci under his name or simply ask him and I believe the class was pro stock 0-600 at the time as stated it works just fine, but your having a hard time believing that, and I did 153.1 at the dash on 6 subs using 1 coil per sub to gain power at 38hz, but ok you know everything right? As I said before Im not going to try and prove you wrong, I said it is possible and it has been done and proven that simple why cant you get that or understand that? Quote Link to comment Share on other sites More sharing options...
