Copper or Aluminum Coil?
I was also thinking about getting a pair of audio que woofers. probally the street duty 15s. So these sub woofers do sound pretty clean and nice?
yes
2 AQ 10'' HDC3 copper subs
1 3500d AQ amp
146.3db on TL with stock electrical in single cab truck at 32hz
RESULT: 1st place at comp, 3rd overall out of 20 cars
copper is just flat out better musically, and copper coils can usualy be put in smaller boxes due to higher Bl on copper than aluminum, and lower Fs etc etc
more spiders, and wire in the aluminum, flat wire is more expensive to wind( if you wanted to get technical) but copper WIRE is more expensive, but only about half as much wire in copper- besides the fact
and just the fact that people will pay another $50 for that extra 500+ handling
edit: twice as much wire in the copper due to copper having a lot less resistance in it, and needing to go with a smaller gauge to match a aluminum wire impedance
copper is usually the best way to go for day 2 day driving and im sure u drive ur car beatin u knoww,,
95 Delta 88
10 inch fubar(2 MB Quart RWE-352 15" on way soon)
1500.1 crunch
kenwood KDC-MP642U
Jp Kustomz
I actually prefer the sound of the alum coils. Mostly listen to rock/metal, but also play rap to demo. I've played around with both extensively, including 16 recones in 3 weeks going back and forth and changing VC imp.
I've done a few builds for guys with 2 15" SDC's and 1200+watts of power. both sound very good, get low, and are plenty loud for daily.
either works well for daily, just depends upon your power level. I run an AQ3500 on each sub and the coppers got stinky too quickly as I was running each amp at .5ohm daily.
  • Who's Online   0 Members, 0 Anonymous, 989 Guests (See full list)
