fi audio Posted December 11, 2009 Report Posted December 11, 2009 Well i found out i aint going to go with 2 btl 18s anymore im just going to add to what i got what im doing is just buying 2 more 12" bl's and 2 more audioque 1200d's so i will have 3 12s and 3 1200ds.... Im not for sure how many batterys should i have and what size alt i should get and can you strap 3 amps i know you can 2 but im unsure about 3? Setup: Headunit: 7" indash screen Sub: fi bl 12 Amp: Audioque 1200D Box Ported tuned to 34hz Big 3 done in 1/0 gauge
Red-navi-916 Posted December 11, 2009 Report Posted December 11, 2009 or just do 2AQ;s for 3 woofers and idk id go with like 3 batteries counting the one under the hood BUILDLOG http://www.stevemeadedesigns.com/board/ind...showtopic=61862 "98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!! Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
Marlo Stanfield Posted December 11, 2009 Report Posted December 11, 2009 You can't strap 3 amps to my knowledge... Just get something like a maxxlink and wire each amp to each woofer. A group 31 per amp would work just fine, HO alt, big 3 obviously, 1/0 wiring, and a decent under hood batt(like a Kinetik 1400 or Yellow Top). 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
fi audio Posted December 11, 2009 Author Report Posted December 11, 2009 You can't strap 3 amps to my knowledge... Just get something like a maxxlink and wire each amp to each woofer. A group 31 per amp would work just fine, HO alt, big 3 obviously, 1/0 wiring, and a decent under hood batt(like a Kinetik 1400 or Yellow Top). what size alt should i get? Setup: Headunit: 7" indash screen Sub: fi bl 12 Amp: Audioque 1200D Box Ported tuned to 34hz Big 3 done in 1/0 gauge
Blackedout Posted December 11, 2009 Report Posted December 11, 2009 300 Amp alt, unless you have a platform that can take more, like a 400. 300 should be just fine, but if you plan on upgrading, I'd consider a 400 amp alt. Trunk Build Log
