Check it out fellas i got this new lap top (im using my deskptop for this) im having trouble with the wireless connection it wont connect and when i try to go in to the settings for it, it takes forever and it doesn't open any ideas on how to fix it
Team Bass-Hz
what kinda laptop
its a toshiba satellite its started to work after i hooked in the ethernet cable and the wifi on it worked after i unplugged
the ethernet cable
if there is anything wrong let me please if not i appreciate u tryin to help
Team Bass-Hz
not sure about windows 7 but this worked on my sisters laptop with windows vista, also a toshiba satellite
Start, All Programs\Accessories and right click on Command Prompt, select "Run as Administrator" to open a command prompt.
In the command prompt window that opens, type type the following commands:
Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
Reset IPv4 TCP/IP stack to installation defaults. netsh int ipv4 reset reset.log
Reset IPv6 TCP/IP stack to installation defaults. netsh int ipv6 reset reset.log
Reboot the machine.
2000 chevy blazer
Avic n1
Do you have a wireless router? If so, WEP/WAP security on it? You can access your router via it's ip address. They vary depending on your wireless router brand.
192.168.2.2
192.168.2.1
192.168.1.1
192.168.1.2
etc etc
or
You can press the windows key
and R then type "CMD".
Next type "ipconfig all" "ipconfig release" "ipconfig renew"
my satellite has a little button in the front that a switch, under the keyboard kinda on the left side.. it turns off my wifi connection, you could have 1 and have accidently hit it
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
  • Who's Online   0 Members, 0 Anonymous, 778 Guests (See full list)
