mentalcase Posted December 14, 2009 Report Posted December 14, 2009 when my amp is hooked up the power light comes on. the protect light DOES NOT come on but it wont put a signal out to my sub...and its all wired right. and it was working fine a day ago! can someone please tell me what might be going on!? 92 Jeep Cherokee big 3 pioneer premire P410ub 2000 watt hifonics pioneer 400.4 4g wire all the way around redoing box for the 2 15s
k3n12ock Posted December 14, 2009 Report Posted December 14, 2009 Check your ground. 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2
mentalcase Posted December 14, 2009 Author Report Posted December 14, 2009 grounds fine i looked at that as well...i think its weird its gettin power but nothings coming out of the amp...could an internal fuse be blown? 92 Jeep Cherokee big 3 pioneer premire P410ub 2000 watt hifonics pioneer 400.4 4g wire all the way around redoing box for the 2 15s
mbdblue Posted December 14, 2009 Report Posted December 14, 2009 grounds fine i looked at that as well...i think its weird its gettin power but nothings coming out of the amp...could an internal fuse be blown? dont think the 2008d came with internal fusing man. Id check all your connections...also might be a crap RCA line... edit:also pull the sub out and check the wiring...if it has push terminals, the wire could have come loose and popped out... AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
Boon Posted December 14, 2009 Report Posted December 14, 2009 Hmm I know a few things it could be but they're slightly trade secrets and I don't think I can share. Is it under warranty? Listen to it really carefully and see if you can hear the output relay turn on, it should be a distinctive TICK about 5 seconds after you give the amp power. 10.x volts fo' life!
mentalcase Posted December 14, 2009 Author Report Posted December 14, 2009 Hmm I know a few things it could be but they're slightly trade secrets and I don't think I can share.Is it under warranty? Listen to it really carefully and see if you can hear the output relay turn on, it should be a distinctive TICK about 5 seconds after you give the amp power. yeah the guy i bought it from still has it under warrenty but its in tennessee and im in georgia...i guess i could ship it but i wanna make sure theres actully something wrong with it first before i send it off 92 Jeep Cherokee big 3 pioneer premire P410ub 2000 watt hifonics pioneer 400.4 4g wire all the way around redoing box for the 2 15s
Boon Posted December 14, 2009 Report Posted December 14, 2009 Check for the click of the relay as above. That's a good place to start 10.x volts fo' life!
