Is This Not The Same Thing?
Local shop wanted to see my basket and mag so I unbolted it and he saw how I had my sub wired and said its wrong. I have mine wired liek the sub on the right with wire nuts so I could run larger speaker wire to each coil. He said that is not a 10hm load on a dual 2 sub lol. I said its still a 1ohm load lol. Am I wrong?
1997 2 Door Blazer
Bagged & Body Dropped
SBC/TH350
yes, they are the same. positive to positive negative to negative. i deem said local shop to be dumbasses.
groundpounders-sig-2.jpg 2002 Tahoe Pioneer 4300dvdFront: Pioneer Components Rear: Kicker CVT6.5 sub amp: US Amps AX2000HC @.35 front stage amp: US Amps TU4360C(tube amps FTW!!)2-18" Level Crossfire XS-SPL V.1'sCheck Out My YouTube Videos!! Click This Now!
it that a dual 2ohm Sub and u want a 1ohm load ?
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Under Construction for 2017
what is positive from 1 coil to neg on the other coil and then neg to pos from that coil back to other coil then running out 1 neg on one side and 1 pos on the other side, i thought that would be a 1ohm load on a 2ohm sub ?
Edited by cubs_fan0718
06 Impala SS
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Man it looks the same to me.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
  • Who's Online   0 Members, 0 Anonymous, 812 Guests (See full list)
