Box help for 2 AQ HDC3 12's
just build a box for same subs.... http://www.stevemeadedesigns.com/board/ind...60&start=60
around 5 cubes net, two 6"aeros, tuned to 37ish...he has yet to get the subs...so not sure how it sounds..lol
but that design should work well for u as well
i would do around 5cubes net, maybe more...tuned from 36-38hz
i likes me some audio stuff...
that box looks tight man. Do you have all the dimensions for it? Yeah i would rather it be 38hz for the type of music i play.
I would like a double baffle too and if its not a problem, could you make it without the kerf ports?
Ya, i got dimmensions for it and a cut list, maybe even a cut sheet somewhere. 2x baffle, all you do is add another sheet of MDF on top, so itll make the box 3/4" taller than mine was. HIGHLY SUGGEST BRACING INTERNALLY 1" dowel rod works great. If you dont brace it, dont be surprised when screws break. Are you in any kinda hurry to get this built or no?
Shit, if youre in the chicago area and got like $40 the box is yours. It isnt the prettiest in person, but it got plenty loud. It wont fit in my trunk, and i dont have any other car to put it in. Its been collecting dust in my garage since Aug.
Edited by siucsaluki11
woman..cant live with em...cant shoot em...guess were all fucked
You might be a Redneck if you use your leftover gutters for a speaker box port...
YOU JUST LOST THE GAMER.I.P. Blazer=========================Last setup was in the 141s on music (37hz) with 2 12s and 1kw in a 4dr blazer.2010 Mitsubishi Lancer DE2 12in Clarions (kept from blazer)HiFonics BRZ1700.1d (at 2 ohms BLOWN) [JBL GTS180X for subs currently 60wRMS x2ch!!!!!! This works for till i get the blown amp fixed] Alpine 4ch salvaged from blazer (currently near death)9887 peerless 7s in the doors and CDT tweeters ran active no speakers in the rearKintik HC1400 under the hood.metered once a while ago, dont remember it...was piss poor compared to the blazer, mid 130s i think....looking to replace subs and amp when i have money.
alright man sweet :D . THANK YOU SO MUCH!yeah a baffle isnt hard to do. i will deffinantly brace the inside. my subs are still breaking in but i would like to maybe get started on it this weekend if possible.
lol sorry man. i live in gonzales LA.
alright, ill try and get those done for ya by the weekend. I work 6a-230p so when i get off i usually am a lazy bastard, or got shit to do. Today was a bit of both. Had to do a lil cleanin, and just overall lazy. But ya, Should be able to get those to ya this week. Should be able to do it with one sheet of MDF too. Thats all mine took, and i fucked up and had to re cut pieces, and your port will be shorter.
alright man thanks again for your help. i really appreciate it.
Will work out a cutlist for you, cut sheet is up to you to figure out.
Top is 1.5 in thick. Port is 15.5 x 5. Box shoud be good as long as you brace it properly. I recommend 1" dowel rod.
SMD_HDC3_BLAZER_cutlist.txt
those blazers like a sub up port to the driver side box better then sub up port back.
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
2 batcap 4000's 1 batcap 2000
dual alts.
154@37hz and climbing
http://www.cardomain.com/ride/3231683
http://www.myspace.com/torque150
  • Who's Online   0 Members, 0 Anonymous, 2163 Guests (See full list)
